Turbo Blanket: Where do I get one of these in black???
I found this on booslogic.com but I cannot seem to find them anywhere else online. I would like to find one in black perferably but would like to know who else makes these.
Please do not post up about DEI turbo blanket, I know about it, I don't like that one at all
Thanks!!
Re: Turbo Blanket: Where do I get one of these in black??? (legendboy)
legendboy hope your joking!!!!!!!!!
In case not, it is to keep the turbo heat inside the turbo instead of radiating out into the engine bay.
I'll check turbonetics website
Re: Turbo Blanket: Where do I get one of these in black??? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">legendboy hope your joking!!!!!!!!!
I'll check turbonetics website</TD></TR></TABLE>
haha ya i know what its for. I'm sure you can get some oem stuff locally. Like semi truck type stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">"High temp" paint has absolutely no thermal insulative properties.</TD></TR></TABLE>
i meant to put the paint on the blanket since he said he wanted it in black.
Who is Mr Robot?
Re: Turbo Blanket: Where do I get one of these in black??? (Mik3)
ya know... DEI makes this really great....
why would he paint the exterior of the blanket? you go drop normal spray paint on a vinyl type material, let it dry and then bend and flex the material... what happens? it cracks
Re: Turbo Blanket: Where do I get one of these in black??? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">ya know... DEI makes this really great.... </TD></TR></TABLE>
made me laugh!!!
turbonetics sells one I think but its most likely like the one I posted the pic of. I can only find it in their .pdf parts pricing guide, no pics.
I've seen one in a denim blue color as well on a car once while I was getting my car dynoed. Owner wasn't around so I don't know where he got it.
made me laugh!!!
Who is Mr Robot?
thats what im here for
if you can, find out what material the exterior is made out of... chances are you could have it dyed by an upholstery shop or something
Who is Mr Robot?
Please do not post up about DEI turbo blanket, I know about it, I don't like that one at all</TD></TR></TABLE>
Re: (Wideopentuning)
good looking on the egay auction. I think I'll get that one!!!!
otherwise, sthperformance price is pretty good!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wideopentuning »</TD></TR><TR><TD CLASS="quote">I just bought the ebay one. Its coming from Alamo Autosport so it should be quality. I will report back how well it works.</TD></TR></TABLE>
Curious how your going to test this and report back? Opinions mean nothing unless backed up with factual data. Keep that in mind.
Re: (Haleiwa-Brando)
Um... How often are these things actually backed up by factual data? Like 0.5% of the time? I'm sure he means he will report on whether the thing stays cool enough to touch and whether it falls apart or not.
Re: (beepy)
yea, really all you can do is give an opinion on whether the underhood temps seem lower.
i've heard the way this things fastens tends to fail and you need to rig up something of your own, but again, its what i heard.......maybe not true.
I thermal coated the turbine housing of my turbo and mani too but my underhood temps are still mad high. I have seen one of these first hand after quite a bit of spirited driving and it, really does help!!!
Re: (mike1114)
Perhaps Im to analyitical. Ah well...
Where does this trapped heat go that this little cover supposedly traps? If you know anything about thermo dynamics you will understand that metal is a very good conductor of heat. This thing cannot trap the heat and make it dissappear. The heat generated has to go somewhere so once the turbo is up to normal operating tempuratures, the heat shield will become of the same heat as the turbo because the turbo is the constant in this simple equation. Next, the ambient air temps under the hood become the same tempurature as the turbo heat shield etc. etc.
If anything, this heat shield simply slows the effects of thermo dynamics where it isn't too much of a concern....say in a drag car that cools down after passing. However, I feel there is no benifit from this piece on a daily driving vehicle where the engine/turbo will be at a constant running tempurature for a long period of time.
just my .02
just my .02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haleiwa-Brando »</TD></TR><TR><TD CLASS="quote">Perhaps Im to analyitical. Ah well...
just my .02 </TD></TR></TABLE>
so the real benefit for a daily driven car would be to get something like a jethot coating to keep heat from radiating too much right?
Re: (igo4bmx)
Haleiwa-Brando...I work in power plants, they get way hotter than any car motor and they use insulation all around the turbine and other areas of the plant.
It helps keep the heat inside that area, I agree, after a certian point heatsoak will occur but it helps none-the-less...
It also helps keeps the turbo itself real hot (somewhat) which it likes for good spool etc...
