Turbo B16 - Quick oil question!
Old Oct 1, 2008 | 01:26 PM
DreTec's Avatar
Default Turbo B16 - Quick oil question!
Hi Guys,
Recently had my B16 turbo'd, had the engine rebuilt, forged internals etc,
Anyway, I didn't think too much about the oil at the time and just dropped some 10w40 Part-Synthetic in there and trailer it to the tuning company...
The gave it a quick tune on the dyno but advised I take out the part-synthetic and drop in some crappy mineral which should seat the rings into the block.
I drove it back though which was a good 90 miles and drained the oil anyway as I had to sort out a couple of leaks.
What should I put back in there now? Mineral, Part-Synth, Full-Synth? Will it make a difference now as i'm sure after 90 miles the rings are either seated good or bad!
Whatever oil it is, it will only be in there for a couple hundred miles (also advised) and then i'll be going for full-synth high brand oil when it go's for it's PROPER TUNE :D
Old Oct 1, 2008 | 02:39 PM
Ls_dx's Avatar
Default Re: Turbo B16 - Quick oil question! (DreTec)
I broke mine in on Castrol or Valvoline 5w30 then after that redline 10w30 and BOOST!
Old Oct 1, 2008 | 07:07 PM
DreTec's Avatar
So I take it if it starts it's life out on Semi-synth it ain't a problem?
Old Oct 4, 2008 | 12:55 PM
LastGenEK's Avatar
Could take longer to seat the rings
If its turbod and you drivin it hard already then the rings are probably seated
boostedteg909
Sep 11, 2011 04:30 AM
fernando.
33
May 1, 2009 09:28 AM
jdmboy94
Apr 8, 2009 09:31 PM
hondacrx2
Oct 11, 2007 03:40 PM
