TUrbo B16 mystery problem
Old Apr 17, 2005 | 12:04 PM
importfan2's Avatar
Default TUrbo B16 mystery problem
heres the deal i go down to try to get my car tuned and we get everything setup,
so start trying to make pulls on the dyno and everytime the car gets over 5k it falls flat on its face and its only making like 120hp and 130tqA(will post sheets later), it just sounds like its popping real bad, I put brand new ngks it, changed rotor ,cap, even another distrubitor that came off a 500 hp car, and still the same thing, the a/f was within range, the car runs fine, no vacum leaks, did a comp test everything is within spec, injectors only running in the mid 70's, me and locash were puzzled in what the hell can it be the issue? lookin at the dyno graph it looked like a ignition problem but then did all that **** and same result, so lets hear what everyone has to say
here is the mods
b16a2 w jdm b16 cams
drag manifold
t3/t4 59 mm .70 a/r cold side/ .48 a/r on the hot side stge 3 wheel
jrc 8in ic
dsm450's
2.5 dp to 3in exhaust
hondata s200
turbonetic evo wastegate 7psi spring
Old Apr 17, 2005 | 12:06 PM
s2kdre's Avatar
Default Re: TUrbo B16 mystery problem (importfan2)
the gap on the plugs might be too big. Is it happenin when vtec kicks in?
Old Apr 17, 2005 | 12:21 PM
importfan2's Avatar
Default Re: TUrbo B16 mystery problem (jdmhonda)
gap is set at .30
Old Apr 17, 2005 | 12:28 PM
s2kdre's Avatar
try lower my tuner gaps them at .22
Old Apr 17, 2005 | 12:44 PM
importfan2's Avatar
i've never heard of n e body running them that close but no two motors are ever the same, ill check wit my tuner and c what he says
Old Apr 17, 2005 | 01:36 PM
importfan2's Avatar
n e body out there
Old Apr 17, 2005 | 02:22 PM
mtber's Avatar
Was base ignition timing set ?
What amount of ignition timing for amount of boost were you running ?
Old Apr 17, 2005 | 02:30 PM
importfan2's Avatar
Default Re: TUrbo B16 mystery problem (mtber)
he set the timing with the hondata, i dont know exactly off hand but ill ask him later and find out, the car isnt running lean
Old Apr 24, 2005 | 11:19 AM
importfan2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">try lower my tuner gaps them at .22</TD></TR></TABLE>
Just came back from the dyno once again, reset the gap of the plugs down to .22, still the same crazy misfire,tried rc 550's ran a little better but still same ****, even pulled 10 deg of timing and still same thing so im lost on what else to do
Old Apr 24, 2005 | 12:59 PM
TheShodan's Avatar
Moderator
what map sensor are you running? If other than stock, please ensure that the 3 bar map sensor that you're using isn't a 2 bar map sensor, for it really throws the Hondata off a bit so that it seems as though it can't boost well.. verify the part number.
Old Apr 24, 2005 | 01:06 PM
importfan2's Avatar
Default Re: (TheShodan)
still runing the stock map sensor dont need a bigger one as of right now since im keeping it under 11psi
Old Apr 24, 2005 | 01:07 PM
importfan2's Avatar
my next step is to replace the cap,rotor,wires, and put in some gsr cams
Old Apr 24, 2005 | 02:52 PM
mrbsponge's Avatar
i have a B16A2 in my hatch that is turbo'd mine is fully built but i ran into some misfiring problems as well, but mine was occuring around the 300 mark.
i tried all the same crap, new dizzy, wires, plugs, gas. i did however gap myplugs at .22 like above said, if i gap them at .25 it goes crazy.
what plugs are you using?
samll bore motors dontl ike timing but for some reason my timing is insanely high, so it may not be that you need to pull timing you may need to add, mine is in the mid to upper 20s before the boost retard
Old Apr 24, 2005 | 10:00 PM
importfan2's Avatar
Default Re: (mrbsponge)
im running ngk's the ones that r a step colder by one range
Mr. Chainsaw
Oct 12, 2011 04:38 AM
TurboChurch
Engine Management and Tuning
17
Nov 23, 2009 01:13 PM
2LiterTurboSeR
Mar 18, 2006 03:11 PM
self_made
Mar 14, 2006 02:27 PM
st00pid
Jan 26, 2003 11:38 AM
