Turbo b16
Step 1: Forget about PSI. It means absolutely nothing. Forget it's even a metric. Make a power goal. Decide your intent with the car (DD is different than autocross is different than drag is different than...). Decide your budget. Then go read the FAQs. Read them again. Read them a third time. Wake up tomorrow and give them another read. Read them until you believe that you have at least a grasp of FI.
https://honda-tech.com/forced-induct...2A%2A-1024174/
step 1 - sell honda
step 2 - buy car that comes with a turbo from the factory that hits 15 psi. end goal met.
honestly you should have been reading and doing research for tens of hours before you started posting up.
Dunno wth that means ^^ but the general consensus is that reading as much information on the subject is the answer to your question, both in broad fundamental terms but also user-built examples that produce similar power and driveability to what you are trying to achieve. There are entire threads dedicated to posting your setup and numbers.
That's a start. You can never know too much before pulling the trigger on something like this.
xwhitchx
29
Mar 10, 2010 08:28 AM
