Turbo on Auto
shure If the tranny will hold up or not depends on the amount of boost. I would swap the auto tranny with a manual or swap a B. You will still need to change the brake pedal to a brake/clutch and install a shifter. Turbo with a tranny swap or a B with a tranny swap either would be good, but I think that the turbo would be less expensive for your car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Haslam »</TD></TR><TR><TD CLASS="quote">will it produse the sneezing sound when gear changing? need to know...</TD></TR></TABLE>
Buy one of those electronic BOVs off Ebay for $25.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick »</TD></TR><TR><TD CLASS="quote">
Buy one of those electronic BOVs off Ebay for $25.</TD></TR></TABLE>
hahahahahahahahaha
"sneezing"
hahahahahahahahaha
"sneezing"
no it will not make the sound...the way a bov works is when you shift gears and let go of the gas pedal, the throttle body closes shut while the turbo is still trying to force air through but the bov just releases the air to prevent it from going back into the compressor. with an automatic, your throttle body is always open ...
