Turbo Advice
Old Aug 3, 2010 | 02:29 AM
flprelude22's Avatar
Default Turbo Advice
Im currently working my h22a turbo build and need some advice on the right turbo manifold and turbo. My current build is as followed. H22a golden sleeved 88mm bore block, cp 9 to 1 pistons, manhle turbo tuff rods, port n polished crank, balance shaft elim. kit. head is P&P, Skunk stage 1 trubo cam, skunk springs and retainers, ferrera valve, ferrera bronze guides, seals, and clips. Fully built block... im trying to reach over 700 hp on my set up. im currently lookin for either a ramhorn or topmount mainifold. leaning to the topmount more. as for a turbo im lookin at a Precision bullet 6265 ball bearing turbo.
Compressor Wheel: 82mm Exducer; 62mm Inducer 57trim
Turbine Wheel: 74mm Inducer; 64.6mm Exducer 76trim (65 Wheel)
Standard 360deg thrust bearing system
That is the turbo specs. is it good enough for my build?
what is a good turbo housing options? leaning toward t4 68ar Vband? thanks
AZ_CIVIC
Oct 31, 2014 01:50 PM
zakura R
Jun 19, 2010 10:44 AM
eg:R
Jul 28, 2005 05:32 PM
prelude beast
Jun 29, 2003 08:00 PM
