turbo is in
Old Aug 1, 2002 | 07:51 AM
bretx0r's Avatar
Default turbo is in
its working good. only problems are that i have no downpipe as you can see and i cant boost above 4-5psi for some reason... must be the gheto charge pipes i dont konw but i havent blown up my car yet and it pulls harder a lot more torquey. blow off valve doesnt work all the time either
that and my engine found places to spew out oil that i never ******* even seen before.
[Modified by bretx0r, 4:56 PM 8/1/2002]
Old Aug 1, 2002 | 07:55 AM
IHaveTurbos's Avatar
Default Re: turbo is in (bretx0r)
Part of the not spooling above 4-5psi is the fact there is no dp, the dp puts enough backpressure for the turbo to be able to spool, also if the BOV is sticking open that could be an issue as well.
Old Aug 1, 2002 | 07:56 AM
Pengo's Avatar
looks good for a custom i guess. i'm guessing u probably have a leak someone in ur piping if your BOV isn't working all the time. are you running an intercooler? i envy all turbos now. esp the sohcs. good to see more pple still have trust in the power of the sohc tho. good luck and have fun
-alan
Old Aug 1, 2002 | 07:57 AM
DSF's Avatar
DSF
Default Re: turbo is in (Hyundai4G63T)
Part of the not spooling above 4-5psi is the fact there is no dp, the dp puts enough backpressure for the turbo to be able to spool.
Uh...say that again?
Old Aug 1, 2002 | 07:58 AM
bretx0r's Avatar
THOUGHT i needed that thing for something the downpipe is going on today
intercooler goes in later. for now ill try to keep the psi low
[Modified by bretx0r, 4:58 PM 8/1/2002]
Old Aug 1, 2002 | 08:01 AM
clendaniel's Avatar
duct tape!
--Ian
Old Aug 1, 2002 | 08:02 AM
bretx0r's Avatar
Default Re: turbo is in (clendaniel)
duct tape!
--Ian
u havent even seen half of it
Old Aug 1, 2002 | 08:04 AM
DSF's Avatar
DSF
duct tape!
--Ian
And you're wondering why you're only pushing 4-5psi Is your wastegate signal line even attached. I see both ports left open...on the wastegate and on the turbo.
Old Aug 1, 2002 | 08:09 AM
bretx0r's Avatar
Default Re: turbo is in (DSF)
i took the line off in hopes it would go above just to see and i forgot to put it back on for the pictures
Old Aug 1, 2002 | 08:57 AM
inspyral's Avatar
missing a headlight bolt
Old Aug 1, 2002 | 09:04 AM
poison's Avatar
Default Re: turbo is in (Pengo)
looks evil for custom
good job man
Old Aug 1, 2002 | 09:06 AM
integra-modder's Avatar
Default Re: turbo is in (inspyral)
people on these boards notice the strangest things sometimes...i wish i had vision like that
Old Aug 1, 2002 | 09:19 AM
MyWhiteCivic's Avatar
Looks pretty good except for the duct tape. Don't drive around to long with the dp open like that. Believe me, it will toast your hood. I got black exhaust crap all over the place too.
Old Aug 1, 2002 | 09:58 AM
Cwest EK's Avatar
duct tape!
--Ian
LMAOOO...dude that was hilarious
Old Aug 1, 2002 | 10:01 AM
Reid's Avatar
Global Moderator
Default Re: turbo is in (Cwest EK)
How is your BOV connected?
Old Aug 1, 2002 | 10:11 AM
Ri5e's Avatar
Default Re: turbo is in (Reid)
Looks like the BOV is duct taped on?
Old Aug 1, 2002 | 10:54 AM
bretx0r's Avatar
Default Re: turbo is in (BG Boost)
its welded and the duct tape looks beter than the weld. trust me
Old Aug 1, 2002 | 11:14 AM
*Boostwerks*'s Avatar
no......
The turbo may spool FASTER creating a faster spool up....there should be NO change in boost, unless the flow is by-passing the wastegate valve. In that case even, the boost should INCREASE.
It's most likely the WG actuator that is limiting the boost.
Old Aug 1, 2002 | 01:16 PM
bretx0r's Avatar
Default Re: turbo is in (Bryson)
i disconnected the tube. ill try disconnecting the arm
Old Aug 1, 2002 | 04:44 PM
paulzy's Avatar
not having a dp will not affect how much boost you're seeing, if anything it'll creeep and spool faster
Old Aug 1, 2002 | 07:11 PM
Jockobo's Avatar
Default Re: turbo is in (Slow_ass_4dr)
is that a dx header?? how did u get the turbo to fit???
Old Aug 1, 2002 | 08:33 PM
FredoSP's Avatar
lol im still laughing ...looks ghetto, but hey if it works ..
Old Aug 2, 2002 | 07:59 AM
Default Re: turbo is in (FredoSP)
shhhhhhh...
its the ultimate sleeper when you pop the hood
Old Aug 2, 2002 | 08:06 AM
bretx0r's Avatar
how do you explain it not going above 5psi?
it hit 8psi ONCE then it never hit 8 again
[Modified by bretx0r, 5:07 PM 8/2/2002]
Old Aug 2, 2002 | 09:36 AM
bretx0r's Avatar
any suggestions?
