Tunned & detionation??
Old Oct 20, 2003 | 06:07 PM
R-1303's Avatar
Default Tunned & detionation??
I have a 2000 ITR boosted on a drag 3 kit, its hondata tunned (s200), but why I am I still detionating?? Jeff at Import builders tunned it for me.
Could it be becuase I still have the drag inline fuel pump and not a walboro intank??. the injector size is Rc 440's.
Old Oct 20, 2003 | 06:44 PM
drvfast's Avatar
Default Re: Tunned & detionation?? (R-1303)
get the intank fuel pump
Old Oct 20, 2003 | 07:43 PM
kungfuSiR's Avatar
Knock can be cause by many things, my first question would be how do you know it's knocking and perhaps not something else?
Do you have any type of air fuel monitor or EGT gauge that you can monitor to see what your fuel and temperature's are on the street?
Where is the knock happening, low RPM when you increase load? that would suggest perhaps too much timming etc ... there's many things to look at
Old Oct 20, 2003 | 08:21 PM
R-1303's Avatar
Default Re: (kungfuSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kungfuSiR &raquo;</TD></TR><TR><TD CLASS="quote">Knock can be cause by many things, my first question would be how do you know it's knocking and perhaps not something else?
Where is the knock happening, low RPM when you increase load? that would suggest perhaps too much timming etc ... there's many things to look at</TD></TR></TABLE>
Knock? it said detionation....sounds like a grain of rice in a tin can, also it happens at load about 6500 rpm into vtec....can it be the fuel pump or tunner??
Old Oct 20, 2003 | 09:15 PM
racinskittle's Avatar
Default Re: (R-1303)
i wonder what the fuel maps look like. Lack of fuel at VTEC?
Old Oct 20, 2003 | 10:00 PM
Scott_Tucker's Avatar
If it's truly knocking (detonating) you can stop it by either richening the air/fuel mixture to quench the flame or you can retard the ignition timing. Either way its a tuning issue.
Old Oct 20, 2003 | 10:49 PM
R-1303's Avatar
Default Re: (AutoEng2002Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoEng2002Si &raquo;</TD></TR><TR><TD CLASS="quote">If it's truly knocking (detonating) you can stop it by either richening the air/fuel mixture to quench the flame or you can retard the ignition timing. Either way its a tuning issue.</TD></TR></TABLE>
Can't retard the timming anymore, from what i hear...Jeff said its retard to the max, so i'll get retunned by church's this time..with the walboro and fuel pressure regulator.
madcrx69
Aug 15, 2017 09:26 PM
B18c1vicrx
Aug 29, 2007 08:47 PM
sircrxracer
Dec 27, 2003 05:32 PM
R-1303
Oct 25, 2003 05:54 PM
BoostedSi
Feb 4, 2002 03:23 PM
