Tuning experts i need some help...
Old Jan 3, 2004 | 07:02 PM
D@nnY's Avatar
Default Tuning experts i need some help...
My cars hondata was tuned for 756cc injectors on a 9.1 comp 84 mm gsr. from the guy i got it from who no longer is answering his email and his member name on hondatech is gone. "homesk1et" The hondata is in my 84 mm 9.1 gsr with a prec sc61. But i have 880 ccs. The car runs alright the way it is with a vafc set at -8 percent across the board but at high rpm the power falls off bad. no cuts but i cant tell if its way to rich or not. its only at high rpms . I also dont have any idea what to set the ignition timing at idle to manually. right now its retarded about 8 deg at idle to be safe. WHAT DO I SET THE TIMING AT? how much should i lean it out till i can get it tuned. im trying to get money together ...--also when the car hits vtec is when it bogs out bad..timing ? fuel?
Old Jan 3, 2004 | 07:17 PM
boostn420's Avatar
Default Re: Tuning experts i need some help... (GSRT37)
You need to find the nearest tuner and ask them for a base map for your setup until you have money for a real tune. Try 12 degrees
Old Jan 3, 2004 | 09:05 PM
D@nnY's Avatar
12 retarded or 12 deg beforef tdc? yea the car is breaking up bad if it goes into vtec..bump for help --anyone around got a base map
Old Jan 3, 2004 | 09:42 PM
D@nnY's Avatar
i just slammed the distributor as far as it would advance and its still 3 deg retarded at idle..WTF
Old Jan 4, 2004 | 10:30 AM
D@nnY's Avatar
bumpbump
Old Jan 7, 2004 | 07:55 PM
R@mon's Avatar
Default Re: (GSRT37)
why dont you check and make sure the crank/cam timming is correct?
BTW this is Ramon From PACT
Old Jan 7, 2004 | 08:20 PM
D@nnY's Avatar
car is not bogging at all anymore.. changed plugs and fixed a few things.. by the way whatrs up man
zpayne21
Engine Management and Tuning
Dec 19, 2015 12:08 PM
AssHammer
Mar 30, 2011 10:18 PM
ruffrhyder
Aug 13, 2010 09:21 PM
D@nnY
Dec 29, 2003 11:38 PM
