Tuning?
Old Jan 18, 2004 | 10:01 AM
rocket256's Avatar
Default Tuning?
Ok; searched but could not find anything. The question is what is the difference between a conservative tune and an aggressive tune? Ie A/F ratio, timing, etc.......
Which is better for street and still make good power for the track?
Also does your bore have anything to do with it?
Old Jan 18, 2004 | 10:57 AM
RedTegLS's Avatar
Default Re: Tuning? (rocket256)
A conservative tune will have a richer A/F and more timing. While the more agressive tune will lean it out a little and retard a little more timing. That is the key to a good tuner....being able to find the middle ground between making power and blowing up the motor. If I said any of that wrong please correct me.
Old Jan 18, 2004 | 12:23 PM
808b18c1boosted's Avatar
Default Re: Tuning? (RedTegLS)
you have to retard the timing for a conservative tune not advance it.
too much advance + boost = knock knock boom
Old Jan 18, 2004 | 12:40 PM
Professor15's Avatar
wat does retarding the timing actually do? tia
Old Jan 18, 2004 | 04:00 PM
rtype11's Avatar
Default Re: Tuning? (808b18c1boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808b18c1boosted &raquo;</TD></TR><TR><TD CLASS="quote">you have to retard the timing for a conservative tune not advance it.
too much advance + boost = knock knock boom</TD></TR></TABLE>
not all together true - if you retard too much you dramatically increase cylinder pressure/temps, this could lead to lifting the head/blowing out headgasket, exploding plugs etc....
Old Jan 19, 2004 | 12:19 AM
rocket256's Avatar
Default Re: Tuning? (rtype11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rtype11 &raquo;</TD></TR><TR><TD CLASS="quote">
not all together true - if you retard too much you dramatically increase cylinder pressure/temps, this could lead to lifting the head/blowing out headgasket, exploding plugs etc....</TD></TR></TABLE>
True; but doesnt increasing cylinder pressure/temps equal more hp?
Old Jan 19, 2004 | 06:14 AM
JDogg's Avatar
less timing will normally result in lower cylinder pressure and slightly higher egt's. you cool the egts by running richer.
with proper engine management you dont have to worry about it as long as the corrections are setup properly.
Old Jan 19, 2004 | 06:25 AM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">True; but doesnt increasing cylinder pressure/temps equal more hp?</TD></TR></TABLE>
I said "too much" a lot of pople continue to pull out timing as they see HP increase, there is a point where a couple additional HP from retard equal certain disaster. running too rich is also bad as it washes the cylinders and ends up past the rings, shortening the lifespan of your motor. there are a thousand combinations.
asianspeed
Dec 4, 2007 07:01 PM
turbo boost
Oct 19, 2007 01:57 PM
SOHC_MShue
Sep 17, 2006 09:47 PM
ID_ten_T
Jan 20, 2004 07:11 PM
TurboDANDEE
Oct 8, 2002 03:54 PM
