Tuning
Old Aug 26, 2002 | 07:26 PM
td04civic's Avatar
Default Tuning
I'm building a d16z6 motor to run 15psi. I'm using a 91 si ecu and i noticed that hondata and Aem don't make a engine management system for my ecu. What other option do i have?
Thanks
Old Aug 26, 2002 | 07:40 PM
ekb18c's Avatar
Default Re: Tuning (td04civic)
Options for ecu's that are plug and play? That was it, hondata and aem.
You can go with dfi, haltech, motec, tons of others.
Old Aug 27, 2002 | 07:46 AM
racerxadam's Avatar
zdyne does OBD-0 ecu's. http://www.zdyne.com/
Old Aug 27, 2002 | 10:46 AM
Charlie Moua's Avatar
Default Re: Tuning (racerxadam)
I'm guessing that you have a ef. right? if so you need to convert to OBD1(afew added wires, injecotrs, distubutor, ecu,) then get hondata.
Old Aug 27, 2002 | 12:56 PM
ion_four's Avatar
Why would you want to use a 91Si ecm to run a z6? You aren't going to be taking advantage of vtec. if you don't want to convert to odb 1 you should get a zc, and a Zdyne standalone, me thinks.
Old Aug 27, 2002 | 01:00 PM
technine's Avatar
zdyne ecu... go to http://www.zdyne.com foo
JDMF22B
Honda S2000
24
Jan 25, 2010 04:59 AM
cantaffordaccord
Engine Management and Tuning
Oct 11, 2009 04:02 AM
crampinyourstyle
Aug 17, 2006 10:41 AM
TurboGSR96
Mar 13, 2006 06:44 PM
ceLtic
Mar 10, 2004 05:50 AM
