Tuning
Old Aug 29, 2005 | 02:17 PM
EJ8 GSR-T's Avatar
Default Tuning
t25 turbo setup...what do i need to get in the way of tunign/ fuel? do i need a new fmu? and i wsa gonna get a greddy e-manage....are they good?...i was lookin to buy a new in box emanage off of ebay, is that all i would need if runin stock injectors and such? does it include all needed cables and such?
Old Aug 29, 2005 | 02:23 PM
mtber's Avatar
Default Re: Tuning (userdead626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">t25 turbo setup...what do i need to get in the way of tunign/ fuel? do i need a new fmu? and i wsa gonna get a greddy e-manage....are they good?...i was lookin to buy a new in box emanage off of ebay, is that all i would need if runin stock injectors and such? does it include all needed cables and such? </TD></TR></TABLE>
All you need is the proper sized injectors, fuel pump & a electronic fuel management system such as a chipped obd1 ecu running crome, hondata, uberdata, neptune etc.
Old Aug 29, 2005 | 02:40 PM
EJ8 GSR-T's Avatar
Default Re: Tuning (mtber)
what if obd 1 is not an option
Old Aug 29, 2005 | 02:43 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">what if obd 1 is not an option</TD></TR></TABLE>
Then run AEM ems :-)
Old Aug 29, 2005 | 02:53 PM
EJ8 GSR-T's Avatar
**** if only i could...haha so emanage is no good?
Old Aug 29, 2005 | 02:55 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">**** if only i could...haha so emanage is no good?</TD></TR></TABLE>
I wouldnt run emanage unless I had to.
Old Aug 29, 2005 | 03:07 PM
EJ8 GSR-T's Avatar
**** so without 2000$ or obd 1 what are my options? i want good tuning so ill have a reliable car
Old Aug 29, 2005 | 04:04 PM
adseguy's Avatar
You can run OBDI on a normally OBDII car. A lot of people do it. It's just a harness.
The best bang for your Buck will be a Crome/Uberdata/Neptune system. AEM is good but too expensive and everything else is a little half *** and not good for above 6-7PSI.
Old Aug 29, 2005 | 04:07 PM
Electron_LS-Vtec's Avatar
Rule of thumb FMU= JUNK the emanage doesnt give you enough adjustment for most turbo setups. Depending on your motor and how much boost you are planning on running than you might be able to get away with a SAFCII or a VAFCII . If you are just running a stock motor with a mild turbo setup which is what you sound like you are doing than i would just get some DSM injectors and run a VAFCII . You are going to need someone to tune it for you because it will run rich as **** with the stock program and DSM injectors. Make a plan on someone tuning it before you install either one of these items. I dont understand why OBD 1 is not an option. It is always an option because they make conversion harnesses for all different systems. I would just reccomend getting a chipped OBD 1 ecu and call it a day. get some one to tune it with chrome and you will be good. The only way I can see OBD 1 not being an option is if you just dont want to fork over the money needed to convert which isnt very much anyways.
thanks
-Drew
Old Aug 29, 2005 | 05:23 PM
EJ8 GSR-T's Avatar
Default Re: Tuning (Electron_LS-Vtec)
obd 1 makes cars impossible to ever sell....and i cant get it inspected
Old Aug 29, 2005 | 05:34 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by userdead626 &raquo;</TD></TR><TR><TD CLASS="quote">obd 1 makes cars impossible to ever sell....and i cant get it inspected</TD></TR></TABLE>
that is why you keep the stock injectors and ecu to get it inspected... And then let it be someone else's problem. That is the most cost effective way to do it.
Old Aug 29, 2005 | 06:11 PM
kell211's Avatar
Default Re: Tuning (93turbo16)
it's a common misconception on this and many forums that you can't make power on an emange, and that they are no different than a afc. These are wrong. I'm currently making over 408 hp and 313 tq on an emanage. 11.7:1 a/f no detonation shown on the plugs on 20 psi of boost. There are limitations to the emange, but they are usually higher than the power levels people make.
Old Aug 29, 2005 | 06:35 PM
all go teg's Avatar
Default Re: Tuning (kell211)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kell211 &raquo;</TD></TR><TR><TD CLASS="quote">it's a common misconception on this and many forums that you can't make power on an emange, and that they are no different than a afc. These are wrong </TD></TR></TABLE>
so if you were going to be building a daily driver would you have a problem in putting in an afc and having it reliable?
ps. sorry for the thread jack but id like to here from some one that's done it,and not just from the guys that run standalone and look down on afc hacks
Old Aug 29, 2005 | 07:11 PM
93turbo16's Avatar
Default Re: Tuning (all go teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all go teg &raquo;</TD></TR><TR><TD CLASS="quote">
ps. sorry for the thread jack but id like to here from some one that's done it,and not just from the guys that run standalone and look down on afc hacks</TD></TR></TABLE>
I ran the afc in my car and in others for a while. I believe the emange can control timing as well, but I am not 100 percent how to use it, I will be using it on a 240 soon with an sr20 swap. I just think that there isn't a real need for an emanage with a honda, maybe I am dead wrong here. If it can control ignition as well as uberdata or crome, then there is nothing wrong with it.
But the AFC hack I know cannot control ignition, so why bother, spend the same price for uberdata or crome as you would an afc and an MSD retard box.
Old Aug 29, 2005 | 08:40 PM
rkrone's Avatar
i got an ecu from racingchips.com running with 440 cc injectors, 255 fuel pump, no problems, it runs the injectors like stock until boost, i get 30 mpg and when i hit the gas the tires brake loose!
a conversion harness is like $100, the ecu is around 200
Old Aug 30, 2005 | 04:03 PM
kell211's Avatar
Default Re: Tuning (rkrone)
running an afc hack, maybe. Depends on how much boost. An afc can't control ignition timing, yet the fact that lots of people have done it successfully over the years says it can be done. But without the ability to adjust timing it's very limited.
But an afc can't be compared to an emanage. The emanage can control fuel injectors by manipulating map sensor voltage, like an afc, but it doesn't have to. You can increase fuel by increasing the injectors duty cycle. And you can control timing +/- 20 degrees. Doing it with an emange just isn't as easy as a stand alone. You have to clamp the map sensor at 3v and then from that point on write your own fuel and ignition maps. It just gets a little confusing that's all.
Old Aug 30, 2005 | 04:19 PM
EJ8 GSR-T's Avatar
well im obviously not gonna be doin the tuning myself....so is e-manage the way to go if the shops tunin it? who would be able to tune uberdata or chrome? and why will it not work on my obdII ecu?
Old Aug 30, 2005 | 04:22 PM
tony1's Avatar
I can set you up with NepTune for less than an afc or emanage, and it'll do ALOT more. Give me call at the shop if you're interested in getting tuned.
Tony
Old Aug 30, 2005 | 06:24 PM
93turbo16's Avatar
Default Re: Tuning (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I can set you up with NepTune for less than an afc or emanage, and it'll do ALOT more. Give me call at the shop if you're interested in getting tuned.
Tony
^^^ solves all your porblems.
Uberdata and crome work off of OBD1 code. And plus not many people even chip OBDII ecus, let alone have a rom editor for them. That is why they don't work for OBDII ecus.
Old Aug 30, 2005 | 06:30 PM
EJ8 GSR-T's Avatar
whats neptune? never herd of it....so does it work with obdII?
Old Aug 30, 2005 | 06:33 PM
93turbo16's Avatar
No it still uses OBD1, honestly just convert to OBD1, it will solve all your tuning problems. Keep the stock injectors and stock OBD2 ecu. And put them in for inspection.
Old Aug 30, 2005 | 07:53 PM
EJ8 GSR-T's Avatar
so do i just get an ecu from an older civic?
Old Aug 30, 2005 | 08:07 PM
boosted k20's Avatar
what car do u have? from ur avatar looks like a civic or RSX. if u have a 2000 and older car then just get a OBD1 ecu with jumper harness and run crome,uberdata,hondata,neptune. simple solution. just do like what was stated:keep ur stock injectors and ecu and plug them in when u r gonna get inspected. thats what i do
Old Aug 30, 2005 | 08:12 PM
EJ8 GSR-T's Avatar
Default Re: Tuning (boosted k20)
ok well does the tuner/shop install chrome/uberdata and such or is it a physical plug in? also are there any prob. when you put your old ecu in for inspection?
Old Aug 31, 2005 | 05:09 AM
uberdata/crome/neptune/hondata all use OBD1 ecu's. u need to socket or chip the ecu. the chip u install in the ecu is what they use to tune the car with. it programs all the fuel and igniton maps plus rev limits, vtec points, etc.
u can look for a chipped ecu on ebay or right here on honda-tech, then get a basemap for ur setup and find someone around ur area that tunes the prgram u have. u MUST find someone who can tune that specific program u have (crome, uberdata, etc)
when u plug in ur stock OBDII ecu u will need to install the stock injectors back in. (if u r run n bigger injectors that r low impedance u will need to use a resistor box. but when it comes time to put ur stock injectors back in - high impedance, u will need to by pass the resistor box. I've seen people wire in the resistor box and also keep the stock injector wiring still attached so when it comes time to get inspected, they just unplg the bigger injectors, put the stock ones in and plug them right in. complete plug and play)
