tubular or cast
Old Sep 27, 2005 | 10:20 AM
slowDA's Avatar
Default tubular or cast
i am looking to get a turbo manafold and i was wondering what to go with i heard that tubular will make boost faster but they have problems cracking. and cast will last longer but not make as much power
Old Sep 27, 2005 | 10:22 AM
JDMJoe2000's Avatar
Default Re: tubular or cast (slowDA)
tubblar is good cast is bad simple geometrics
fast air make free spinning wheels better. equula lentght beats log. helps if you vetech the car
tony
Old Sep 27, 2005 | 10:28 AM
urbansi's Avatar
Default Re: tubular or cast (JDMJoe2000)
i would say it depends on you goals, different runners make for differnt power, while on a honda its not like you are going to pick up gobs of tq from differences in runner length but there will be differences in the way power is made depending on the length and size of the cast to the tubular.
edit: ignore everything that jdmjo2000 or what ever says, i hope he was kidding for the sake of humanity
Old Sep 27, 2005 | 10:35 AM
q45mm's Avatar
If you go to garret turbos they explain it there I found it very helpful they prettty much teach you about syles and what they do
good luck
matter of fact heres the link
http://www.turbobygarrett.com/....html
Old Sep 27, 2005 | 10:46 AM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJoe2000 &raquo;</TD></TR><TR><TD CLASS="quote">tubblar is good cast is bad simple geometrics
tony</TD></TR></TABLE>
AM I the only one that thinks that this is sig material?
Old Sep 27, 2005 | 11:41 AM
redzcstandardhatch's Avatar
something different
hahahahahahahaha!
Old Sep 27, 2005 | 11:50 AM
97turbols's Avatar
Default Re: tubular or cast (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">
AM I the only one that thinks that this is sig material?</TD></TR></TABLE>
everything this guy says is sig material!!
Old Sep 27, 2005 | 12:02 PM
2lude4u's Avatar
Default Re: tubular or cast (97turbols)
To get back to the subject (though we all look forward to more insightful info from Jdmjoe2000) I would suggest tubular.
I had a custom tubular manifold that effectively spooled a T70 on my built H22. Tubular manifolds help with better spooling and reduce the opportunity for reversion. Their "weakness" is longevity. My manifold did get a few cracks overtime, that were simply rewelded. One thing to do to help avoid cracking is to fabricate a support or two that is connected to the block and to the turbo to help support the weight of the turbo, thus putting less stress on your hot manifold.
Old Sep 27, 2005 | 12:03 PM
BoOstedEM1's Avatar
Thats defent sig material.
Old Sep 27, 2005 | 12:06 PM
JDMJoe2000's Avatar
i heelp and no repsect from ne 1. more smootth pipes = better flow air and spoolin . which meean no leakeage in the diaghram. trust and check feul supply to the rail which incerease combustion hence boost leeak gone. cya. make surre to rev past 3.5k rpms to increease voltage. get msd ignition ii have that boom.
tony.
Old Sep 27, 2005 | 12:08 PM
andysila's Avatar
Default Re: tubular or cast (BoOstedEM1)
Equal Length it could be more expensive than a log. but if you havent seen the Full-Race manifold comparison, here it is:
just by changing the manifold, they gained a good number of horsepower.
http://fugu.trnetworks.net/~ge....mpeg
its worth the time downloading..
Old Sep 27, 2005 | 12:12 PM
rmcdaniels's Avatar
OMFG, I can't decide which one to use, ROFL.
Old Sep 27, 2005 | 12:21 PM
rmcdaniels's Avatar
Default Re: (rmcdaniels)
And back on topic, I've used both, and my Inline Pro cast manifold started spooling faster, but finished later, while my Lovefab SST started spooling later, but made a bunch more top end power.
It depends on what you are using it for. If it's a DD making 250-300 WHP, then use a small turbo and a cast manifold, cheap and gets the job done with a quick spool. If you want to make 400+ on a built motor, then a quality tubular manifold may be a better bet as it will let you spool a bigger turbo faster and make more top end power with a smaller turbo, but good ones are very expensive
I'll put in a plug for Cody at Lovefab here, he made me a good-fitting rock-solid manifold, gauranteed it for life, and I abused it with constant drag racing, using anti-lag (very tough on manifolds), and extended 400+ WHP road course racing at &gt;20 PSI: it held up great and still looks and works like new. I've seen a lot of other manifolds crack under far less abuse. Plus everyone who has ever seen it has said it is a work of art. http://www.lovefab.com
Old Sep 27, 2005 | 12:23 PM
JDMJoe2000's Avatar
rmcdaniels just cuz u dont no the knowwlege behind turbogenetics becuz the air free flow with the timeing overturned bet u ddidnt know that. newayz get reality going b4 dissin away. i havea 10sec civic and its vetech...thats right. word vtech biginjectior and aem fuel reg, u goin down. aight. i'm running 35lbs of boost my ride with pipe smooth manifold spool it up
tony.
Old Sep 27, 2005 | 12:31 PM
rmcdaniels's Avatar
Dude, stop it, you're going to get me in trouble at work. Everyone's looking at me because I'm sitting in my cube laughing my *** off.
Old Sep 27, 2005 | 12:32 PM
something different
i cannot believe he just explained turbocharging so effectively. such elegance with the language of english.
jdmjoe is probably my favorite person on honda-tech now.
you made my day man. hilarious.
Old Sep 27, 2005 | 12:41 PM
Boostfed's Avatar
New User
Default Re: (jerseykid609)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">
Is that english?
stop posting god. </TD></TR></TABLE>
John I DO NOT KNOW HOW he has lasted a week on H-T without being banned!!!!!! WTF?
Old Sep 27, 2005 | 12:45 PM
rmcdaniels's Avatar
Default Re: (Boostfed.com)
Maybe a moderator speaks his native language and he's actually some kind of genius. I will have to study his writings and see if enlightenment hits me.
Old Sep 27, 2005 | 12:48 PM
andysila's Avatar
i think hes one of those idiots who make a fake name just to be dumb.
10 second civic???? vetech??????
Old Sep 27, 2005 | 12:49 PM
rmcdaniels's Avatar
Default Re: (andysila)
that's probably right, but it's still some funny stuff
Old Sep 27, 2005 | 01:07 PM
Axel Foley's Avatar
Default Re: (JDMJoe2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJoe2000 &raquo;</TD></TR><TR><TD CLASS="quote">rmcdaniels just cuz u dont no the knowwlege behind turbogenetics becuz the air free flow with the timeing overturned bet u ddidnt know that. newayz get reality going b4 dissin away. i havea 10sec civic and its vetech...thats right. word vtech biginjectior and aem fuel reg, u goin down. aight. i'm running 35lbs of boost my ride with pipe smooth manifold spool it up
tony.</TD></TR></TABLE>
this one had me laughing out loud, everyone at work's like " tom whats so funny"
Old Sep 27, 2005 | 03:26 PM
huntarrr's Avatar
Default Re: (Cursd1)
aktualy me's herd dat teh toobular egg shaped wuz not crak unlez yous git da turdogenetics cuz dat haz bad trigonomiks
Old Sep 27, 2005 | 03:38 PM
ginoboy1978's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowDA &raquo;</TD></TR><TR><TD CLASS="quote">i am looking to get a turbo manafold and i was wondering what to go with i heard that tubular will make boost faster but they have problems cracking. and cast will last longer but not make as much power</TD></TR></TABLE>
I would go for a high flow manifold. Just brace it properly though(ie. turbo to the block). But there are also alot of good log mani's available too.
jdmJoe........you freakin rule. Made my day.
DAN
Old Sep 27, 2005 | 07:26 PM
Erik_Pb_Foot's Avatar
New User
Default Re: tubular or cast (ginoboy1978)
freakin' awesome
Old Sep 27, 2005 | 07:33 PM
kasso's Avatar
please ban!!!!!!!
