Trying to find supercharger for mini me/not turbo
Old 10-23-2013, 01:16 PM
  #26
89LSED's Avatar
Default Re: Trying to find supercharger for mini me/not turbo
Im really hoping it will.... why would it not?
Old 10-23-2013, 01:31 PM
  #27
Freemananana's Avatar
I researched the guy that supercharged his B20 in a Del Sol. Good work. But it only made 153wkw, which is about 200 whp. Not downplaying that. But it's not going to be as beneficial (number wise) as a turbo charger system. The TQ specs weren't included from what I read. But I assume it is probably 230 ft-lbs+ from what I read about the toyota previa it came from.
Old 10-23-2013, 01:33 PM
  #28
92cxyd's Avatar
Originally Posted by Freemananana
Do you know what kind of gains you got from this supercharger?
Yeap the first dyno result was 180whp the second with improvements 220whp
I'll dig up dyno slips here soon.
the New Zealander thread I posted up a few post back reached 240+ w/ his B16.
My Twincharge setup has this S/C and a HE351ve on it now w/ 1200cc inj. I can hit 30+psig (max out my boost gauge) @ 7k revs.
No Dyno results on that setup yet.
My turbo oil drain is leaking a bit and the dyno near me wants it fix before I can put it on for the numbers.
Old 10-23-2013, 02:56 PM
  #29
Oh. Didn't know he went that high with the B16. I assume the B18C went higher since he said it was the highest HP. I couldn't see any of the pictures on his thread though, so I didn't see the dyno graphs.
Do you have internals on your set up? 30 PSI seems very high (I know it's all relative) to push stock internals. Whats your estimated HP on the twincharge set up?
Old 10-23-2013, 03:03 PM
  #30
92cxyd's Avatar
Cunningham Rods, 0.5mm o/s YCP vitaras w/ light ported head y8 head.
Twincharge setup 425ish max. (b/c turbo size) but I expect it to be lower in the 350whp due to altitude (5100ft and wear and tear on the turbo, needs a a rebuild)
Thinking of building full forge internals and Darton sleeves in the next couple years.
The original S/C setup was on a stock z6 setup and it was awesome maxing out the 450cc inj.
Old 10-24-2013, 02:41 AM
  #31
I wanna see some engine bay shots of the twin charge system. It would be cool to see what kind of gains you can get in the low end with the addition of a supercharger.
Old 10-24-2013, 04:12 AM
  #32
92cxyd's Avatar
With the radiator support unbolted (I made mine bolt on and off)
I'll post the Dyno sheet when I get home from work.
Old 10-24-2013, 04:30 AM
  #33
That's pretty nice. I was just wondering if you had a graph with and without the supercharger. To compare it to just a turbo system.
Old 10-25-2013, 11:12 AM
  #34
crxsi1's Avatar
Wow... very impressive... if that supercharger is still on ebay in a week im gonna scoop it up...
Old 10-25-2013, 09:03 PM
  #35
crxsi1's Avatar
Dam that supercharger is no longer listed but I will be looking for one... at least a little cheaper then the others listed... im wondering can If I get a fuel pump can I use my stock inj. From my y8 head?
Old 10-25-2013, 09:39 PM
  #36
crxsi1's Avatar
I have a y8 ecu, can I use my p2p or do I need a p28...
Old 10-25-2013, 09:51 PM
  #37
crxsi1's Avatar
And my engine harness is the stock harness that came with the car... which was a d16y7. It just has a d15b8 wired in. So its an obd2 car with obd1 engine... I actaully have to hook up an o2 simulator to pass emissions because of the one o2. So with my setup what fuel arrangement would you go with... keep in mind not budget but oem... I would like to build this using as much oem parts as possible... so if I needed to get inj. I would go w probably the dsm injectors depending on easyness cause they are oem technically, ect... now I know I have to get some aftermarket parts to make it work properly like a front mount, ect... so just let me know a good path if u could...thanks
Old 10-25-2013, 10:04 PM
  #38
crxsi1's Avatar
Could I just send it in to a company and get it retuned and/or what do I say to them to get it tuned for this sc... I've never dealt with tuning my own ecu for forced induction...
Old 10-26-2013, 05:42 AM
  #39
Dang, that sucks then. Maybe he accepted an offer. You can get a Walbro 190 or 255, pretty sure the 190 will cover your fuel requirements.
I don't know if you can chip the P2P. I don't think it will work because it's one of the annoying ECUs. A P28, P72, ect will all work. Just an OBD1 VTEC ECU with a socket. Or you can get a non-vtec ECU that is converted to VTEC with a socket also.
DSM 440s will work for this superchager. Walbro 190lp fuel pump. Not sure about your emissions. I don't know if superchargers are frowned upon.
You need to have all the components ready and get a chipped ECU. You can turn the SC off since it has that option. Run it on a stock map. Go to the tuner, swap injectors, and let them tune it. It will cost a pretty penny. ~$500
Old 10-26-2013, 05:43 PM
  #40
I CRX I's Avatar
ive got a d-series jackson racing supercharger im looking to get rid of, hmu if your interested.
Old 10-27-2013, 12:17 AM
  #41
Who is Mr Robot?
wantboost's Avatar
I'm definitely interested in your results (so keep me in mind when you get it done ) with the HE351VE, as I have one laying around I've been wanting to use for some time... but I'll be using a pneumatic system to control the VGT system from a 2.5cm housing all the way up to the wide open, 23cm housing... (Holsets VGT system is technically VNT as it slides a nozzle ring that controls the size of the housing)
Old 10-28-2013, 06:12 PM
  #42
92cxyd's Avatar
As promised here are the Dyno sheets from the two times I went to a dyno.
1st was in May '11
2nd was in May '12
I know the twincharge runs a lot better than those but never got to a dyno.
These sheets were from driving from Casper Wyo. to Lynnwood Wa. for RHMT meets.
Dynos are rare in my area, except those who support large diesels.
Old 10-28-2013, 06:32 PM
  #43
Black R's Avatar
Those previa blowers look interesting.
What kinda specs on those things compared to say a Jackson racing bseries one?
Iirc, the m45 was what they used with the dseries.
Old 10-28-2013, 06:45 PM
  #44
92cxyd's Avatar
Previa S/C = SC14/TX15 = ~1460cc/rev ~84cid > M46 and M62/M63 vol.
Specs are in this link under TX15
http://www.ogura-clutch.com/products...egory=3&sort=1
Old 10-29-2013, 02:44 AM
  #45
Who is Mr Robot?
wantboost's Avatar
That turbo dyno looks impressive given the size of the HE351VE, any idea on what you have the VGT/VNT arm set to as far as housing size? how far from full closed/open is it?
246hp/226tq is impressive for a d series in any format, even more so with a large turbo, shows the VGT system definitely has an improvement in the response/power curve. Especially when you consider you're making 200ft/lb before 5,000rpm
what pressure was the turbo dyno at?
Old 10-29-2013, 04:03 AM
  #46
92cxyd's Avatar
VNT @ widest setting, vtec disengaged, ign, timing was way off, had the base set at 18BTDC.
Old 11-14-2013, 01:03 PM
  #47
92cxyd's Avatar
OP any update on this?
freeagent
08-22-2007 10:54 AM
Civicse
10-24-2004 03:16 PM
DigitalFusion
04-30-2003 09:34 AM
Quick Reply: Trying to find supercharger for mini me/not turbo
