is it true?
Old Dec 18, 2002 | 08:31 PM
paulzy's Avatar
Default is it true?
Is it true that you can't use your stock sleeves when building an H22?
Old Dec 18, 2002 | 08:42 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: is it true? (paul_vang)
if you plan on using forged pistons, then yes, it is 100% accurate that you cannot use stock H22 FRM sleeves
Old Dec 18, 2002 | 09:26 PM
rioninja's Avatar
what i'm wondering is how much boost people have been able to push with the stock pistons...
Old Dec 18, 2002 | 09:36 PM
Adi Radoncic's Avatar
On Fire!
Hmmmm now this is a pritty interesting topic Paul, now can someone please explain why it shouldn't be done?? I know that those seals use that Nikoseel (whatever its spelled ) but I'm very curious why it wouldn't work..
A friend of mine just rebuilt his H22a short block using some Wiseco 8.5:1 pistons, Eagle rods and ACL bearings and hasn't had a problem yet, his rings sealed fine and the car runs good but it hasn't been put under the pressures of boost yet ..
Adi
Old Dec 19, 2002 | 07:42 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: is it true? (newgsr)
this topic has been covered a million times in the Prelude forum.... try searching
Old Dec 19, 2002 | 07:52 AM
Boostless97Lude
Guest
Posts: n/a
here, i'll do the filtering for you
originally posted in the Prelude Forum:
by 4bidden
here is what to expect if you dont sleeve before forged pistons...
good luck! lol
by GudeH23a
Here is a little 411 for the people that want it. Pistons of high-performance are 99% of the time made of aluminum. The lighter the piston, the higher your engine can rev as well as obtaining power. Back in the 70's your little idea was introduced. All alloy engines used iron-coated aluminum pistons, basically meaning your block could be linerless. However, its expensive. Go to http://www.dictionary.com if you dont know what expensive means. Iron-coating your pistons does not deliver the performance that nikasil treatment provides.
Nikasil treatment basically coats a layer of nickel-silicon carbide to the inner surface of aluminum cylinders. It will generate even less friction then cast iron sleeves and basically everything is enhanced. But guess what? Your engine uses a fiber reinforced metal cylinder sleeve.
The FRM process is as follows:
A fiber-based material in the form of cylinder sleeve is first inserted to the die of the block. Melted liquid aluminium is poured into the die and integrate with the fiber sleeve. Then the cylinder wall is machined to the desire bore dimension, leaving only 0.5 mm thickness to the fiber sleeve which covers the cylinder wall. It generates lower friction than iron liner, thus improves rev and power. Moreover, the fiber sleeve reinforces the block, allowing the distance between adjacent bores to be reduced yet maintain mechanical strength.
Old Dec 19, 2002 | 08:37 AM
Speedworks801's Avatar
Default Re: is it true? (Boosted97Lude)
You can rebuild and use forged pistons, you just have to use a dry lubricant, on install.
Old Dec 19, 2002 | 08:40 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: is it true? (Speedworks801)
have you had experience with installing forged pistons in a H series.... you can't compare and H to a B b/c the sleeves are made of a different material
Old Dec 19, 2002 | 12:15 PM
paulzy's Avatar
ttt
Old Dec 19, 2002 | 12:24 PM
Boostless97Lude
Guest
Posts: n/a
what, you don't believe me???
Old Dec 19, 2002 | 02:05 PM
paulzy's Avatar
it's not that...I just wanna hear some more stories about stock sleeves...
like Adi said, his buddie's car is running fine
Old Dec 19, 2002 | 03:15 PM
Boostless97Lude
Guest
Posts: n/a
he also said "yet"..... 4bidden didn't have any problems at first, and look what happend
Old Jan 1, 2003 | 10:02 PM
h22apwrd95's Avatar
Boosted97Lude
how many miles were on 4bidden's motor when he found this problem? I was wondering, because that looks pretty serious, and what pistons are they? Wiseco's rings quote that they can be used with nikasil cylinder lining, so, why wouldn't their pistons that go with the rings work also?
mike
Old Jan 1, 2003 | 10:07 PM
BudaKai's Avatar
Not true anymore. For those of you who went to SEMA, and checked out the Wiseco and JE booth you would have seen Forged pistons you can use with the H & F ser-ries blocks without sleeves.
Old Jan 2, 2003 | 03:47 AM
bambooluv's Avatar
Default Re: is it true? (tzsir)
Ive read some where about the wiseco's that you can run them without resleeving.
From what I understand its the rings they produced for it. But for me if you worried about it just go the same route that motormatrix did on his race car , Just get some ARI sleeves there like 200 dollars and you have the mind that your motor is resleeved.just my 2 pennies-pdang
Old Jan 2, 2003 | 12:46 PM
h22apwrd95's Avatar
Default Re: is it true? (bambooluv)
How are the ARI sleeves? I just saw them, and are they available for the stock bore H22? I know that they aren't a full sleeve like GE produces, but basically are used to resleeve scarred cylinder walls and the like.
mike
Old Jan 2, 2003 | 01:32 PM
BudaKai's Avatar
Default Re: is it true? (h22apwrd95)
$200 for the sleeves? How much to get them put in? I can get H22's for dirt cheap.
Old Jan 2, 2003 | 01:54 PM
flip1199's Avatar
has anyone tried these pistons from wiesco or je??? untill i see a motor running with these pistons for 40k miles under boost i'll stick with resleeving. personally i don't see how it would really help having different rings, when u look at to pic above and the whole damn side of the pistons is scraped up...But if u guys wanna go cheap and risk your block and pistons go right ahead...
Old Jan 2, 2003 | 04:26 PM
h22apwrd95's Avatar
Default Re: is it true? (flip1199)
well, my motor was taken apart after 1000 miles, and no signs of any wear yet. I will pop it apart again at 2000 and at 5000 after that. I will keep you guys updated. Everything looks good, so like I said, we'll keep you updated. I have another block that is getting work right now, so, if I have any problems, I will be going to a sleeved block. But, if I don't have to, I won't.
thanks,
Mike (running forged w/o sleeves)
and still running
Old Jan 8, 2003 | 12:14 AM
flip1199's Avatar
Any body know where to get these forged pistons that are supposed to work with stock sleeves???
Old Jan 8, 2003 | 12:43 AM
On Fire!
Race Engineering Inc.
Old Jan 8, 2003 | 03:00 AM
Boostless97Lude
Guest
Posts: n/a
go ahead, do it and learn the hard way
Old Jan 8, 2003 | 03:57 AM
paulzy's Avatar
that's what my V8 loving auto teacher used to tell me when I was still in high school
that was about 6 years ago...looks like he was wrong about imports...
point is: change and new things are great until proven not to be
Old Jan 8, 2003 | 09:33 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: is it true? (1320development)
well, since the stock sleeve of an H22 aren't as thick as say a B18, then you do have a chance at actually breaking a sleeve, if it works out for you, great, if not, then sux for you. i didn't re-sleeve b/c it is a requirement, b/c as some have pointed out there are way around it, but sure as hell didn't want to pull the motor for a 2nd time to do something i should have done the first time around
Old Jan 8, 2003 | 03:45 PM
RyanAutry's Avatar
