Troubleshooting an engine with constant misfires.
Old Feb 10, 2003 | 10:37 AM
  #26
PM-Performance's Avatar
Default Re: Troubleshooting an engine with constant misfires. (VSM EXtasy)
not always . . .what about valve ajustmanet>? when was the last one done ?
Old Feb 10, 2003 | 10:41 AM
  #27
VSM EXtasy's Avatar
Default Re: Troubleshooting an engine with constant misfires. (itr206)
valve adjustment was done about 15k ago. But my engine sounds fine, no tapping. All i hear is the misfire at idle, sometimes it idles perfect. Its then when i hit the gas starts backfiring and the car starts shaking badly.
Also if i had a bad valve or blown rings, wouldn't i have oil all over the plugs??? my cylinder 2 is fouled with fuel but all other cylinder looks good. But there is no oil on the plugs.
[Modified by VSM EXtasy, 7:59 PM 2/10/2003]
Old Feb 10, 2003 | 11:09 AM
  #28
no detonation?
Old Feb 10, 2003 | 11:27 AM
  #29
VSM EXtasy's Avatar
nope, no detonation i can hear.
Old Feb 10, 2003 | 11:32 AM
  #30
you got hondata? maybe try and reburn the mpa and see what happens . i know they wig out sometimes. . its a shot in the dark , but worth a try righttry resettintg the ecu too ?
Old Feb 10, 2003 | 11:48 AM
  #31
shadowdawn's Avatar
I have a question, I misfire but its not audible or even makes a noise/shake. I just get random misfire CEL's granted I just changed out the small orifice for the middle one on my fpr and haven't checked if I got any yet, but what can that be a sign of, if the ecu is throwing random ones but I don't feel it or see the car acting funny in any way, smoking etc...
Old Feb 11, 2003 | 04:30 AM
  #32
Default Re: Troubleshooting an engine with constant misfires. (shadowdawn)
you wont until it throws that code. . . well mine would fluctuate and idle was shitty on and off when 1st started up , thats how i would know and thne the cel would come on rigght away after
Old Feb 11, 2003 | 05:08 AM
  #33
VSM EXtasy's Avatar
I'm using a P28 ecu so i dont even get a CEL.
Old Feb 11, 2003 | 06:22 AM
  #34
GRT's Avatar
GRT
if your boosting alot it could be your spark plugs Most likely the plug gap I know it sounds stupid but try to gap them @ like .022 or .023 and see if that helps
Old Feb 11, 2003 | 06:27 AM
  #35
VSM EXtasy's Avatar
Default Re: Troubleshooting an engine with constant misfires. (GRT)
mine misfires at idle so i know its not the plugs, mine are gapped at .03
Old Feb 11, 2003 | 08:54 AM
  #36
turbosol's Avatar
You said that your #2 plug was fouled with fuel, switch the injector to another cylinder and see if it follows the injector. Maybe its gone bad.
Old Feb 11, 2003 | 01:18 PM
  #37
twkdCD595's Avatar
Default Re: Troubleshooting an engine with constant misfires. (turbosol)
you dont have a cat on that car do you?
hawjboi
17
Nov 11, 2008 08:56 AM
lmike6453
Nov 26, 2007 08:02 PM
johnnyxblaze
Sep 8, 2004 11:49 AM
1hottEG6
Apr 25, 2002 08:01 PM
92HB_HB
Mar 11, 2002 11:16 PM
