Treadstone Intercooler
Old Dec 13, 2015 | 02:15 PM
carlos8's Avatar
Default Treadstone Intercooler
HI, Guys. Long story short while at the shop I work, a client backed up with a big *** Ford van, smashed my bumper cover and intercooler (I had no bumper support).
I had a CX 29x9x3 now totally broke.
The client is paying the repair. I already bought the bumper cover and support!!
I'm indecisive from the TR6 (400hp) or TR8 (500hp). My car have 428whp with only a slow bump in power when replace the turbo and clean the tune after 6 years since I build it. So no apply room for grow, it stay that way.
what is the better choice? The price is only $20.00 difference between the two, being the TR6 more expensive.
Old Dec 13, 2015 | 04:20 PM
TheShodan's Avatar
Moderator
Default Re: Treadstone Intercooler
Those cores aren't great to begin with. So, with that said, if no other choice, go for the bigger one.
Old Dec 13, 2015 | 05:15 PM
carlos8's Avatar
What about this: Vibrant 12810. Size 30" x 9-1/4" x 3-1/4" (725 CFM 550hp rated). $244.86 + $80.00 shipping.
Old Dec 13, 2015 | 07:00 PM
96ekb20's Avatar
the tr1235 is rated at 760hp and 1142 cfm ay 2psi drop for 330
Old Dec 13, 2015 | 07:01 PM
96ekb20's Avatar
or tr1045 860hp 1000cfm at 2psi drop for 345
Old Dec 14, 2015 | 05:37 AM
Dark_Teg's Avatar
What do you base this on? Treadstone always test very well even against Spearco and Garret cores. Racelab did a test where the Treadstone beat an Ebay core both by PSI drop and 20 degree cooler temps. Treadstone intercoolers are very good bang for the buck.
OP: I run a TR11 and love it. Treadstone intercoolers are very well made and cool great at their price point.
Old Dec 14, 2015 | 08:49 AM
TheShodan's Avatar
Moderator
See my intercooler thread specifically made to answer those questions. And treadstone is "ok" and nicer than the Mishimoto or Vibrant cores for certain . But not against Bell, Garrett, or PWR.
Old Dec 14, 2015 | 09:22 AM
Dark_Teg's Avatar
Well their is no doubt its a mid level intercooler. My point was that its a nice upgrade from your typical Ebay offering.
Old Dec 14, 2015 | 09:39 AM
LightningTeg's Avatar
Community Builder
For the price they are nice.
Garrett cores are double the cost.
Old Dec 14, 2015 | 12:38 PM
TheShodan's Avatar
Moderator
Depends upon the core. But I've found the benefits outweigh the costs, from my experience and use.
I'm a snob, I know..but I accept it wholeheartedly
Old Dec 14, 2015 | 12:53 PM
Community Builder
Some hard data on core efficiency would be nice. Seems they rate close to same power capability vs size wise, with the tread stone usually just being .5" thicker then the Garrett. Mine is pretty old (one of their originals). I don't know how good it is compared to anything else. I very well might upgrade if I can save some more space running a smaller but more efficient core, and help airflow into engine.
Old Dec 14, 2015 | 03:27 PM
wantboost's Avatar
Who is Mr Robot?
The Treadstone cores are an improvement over the eBay cores and most of the Mishimoto offerings (from what I've seen personally the eBay and Mishi cores are the same thing). However available documentation for each shows that they all have fairly high pressure drops above 15psi. What bugs me the most is even their largest cores have big pressure drops.
They definitely aren't as nice as the PWR, Bell, and Garrett cores though. However if you know where to look they aren't that expensive. If you ever plan on making more power I would strongly suggest you spend the extra money on a quality intercooler. They are much more efficient in terms of airflow capacity/restriction, temperature reduction, and pressure drop. Not to mention either of these 3 brands always hold their resale value and are very durable. I've had one PWR intercooler for 10 years and you'd never guess it was that old by looking at it.
I've personally never used anything other than quality cores. Like I said I've had my big PWR (12x24x3) for 10 years that will be going on its 3rd car shortly and I have a smaller (8x20x3) that I'll most likely be using on my SVT Focus if I don't go air to water. I'll be using a Garrett or Bell core on my other 2 projects.
Just to give you an idea back in 06 when I bought my SR S13 it came with your typical large core with offset 3" inlet/outlet eBay intercooler. While it was better than no intercooler at all it was far from ideal. Even at 14-15psi on a T25 with minimal piping length and bends it did a poor job of heat exchange and had a slightly elevated pressure drop. I put my big PWR in its place and it was a night and day difference. Less pressure drop, higher temp reduction, lower pressure drop and so on. It even improved throttle response.
The biggest issue with the budget intercooler a is their end tank design. In the case of your typical eBay intercooler the end tanks were very small in overall volume and having the inlet and outlet located on one side of the core results in even poorer performance.
When the inlet/outlet is on one side like that it prevents even airflow distribution across the core and effectively cuts the core surface area in half. You wind up with the bulk of the airflow trying to travel through the core area directly inline with the inlet, whatever airflow can't pass through that area has to make a 90* turn and travel up the small end tank until it makes another 90* turn and travels through the core. Then on the outlet end that air has to make 2 more 90* turns to exit the end tank.
What winds up happening is the core heatsoaks in the area directly inline with the inlet/outlet and that kills what little bit of efficiency the core had in the first place. So obviously you'll see an increase in IATs. The other issue that happens with the remainder of the air having to turn and snake it's way to other areas of the core is a much higher pressure drop and a reduction in airflow capacity.
If you don't believe me then the next time you're on the dyno or do a sustained highway pull stop and put your hand on the front of the intercooler. You'll notice the area between the inlet/outlet is considerably hotter than the rest of the core. You could minimize this by having centered end tanks welded on but by the time you pay to do that you could have purchased a quality intercooler.
The biggest drawback to these budget cores other than their flow limitations is their pressure drop. If you run high pressures (15+) then you'll typically see at least a 2psi difference across the core which only increases with pressure. It doesn't sound like a lot but that pressure difference causes the tubocharger to work harder which means higher compressor outlet temps and ultimately higher IATs due to core heatsoak. Depending on the capabilities of your turbocharger and where you are at in terms of its limit that extra pressure could put you at or beyond its capabilities.
Now all intercoolers have some degree of pressure drop as airflow and pressure increase, that is inherent in their operation because cooler air is more dense and has less volume. Manufacturers try to balance pressure drop with airflow/heat exchange. It's possible to design a core that has the highest reduction in air temps but it's design would result in a crazy high pressure drop. Conversely it's possible to design a core with a minimal pressure drop but then it would have virtually no effect on reducing air temperatures. This is why you see most companies offer one of two designs: tube and fin or bar and plate (I won't get into that here). However the Chinese companies use whatever design is cheapest and typically their pressure drop is solely from a **** poor core design which is why you see most of them have a low airflow rating and high pressure drops. The core itself is so restrictive that as airflow and pressure increase so does restriction.
Whatever you decide on make sure the intercooler you pick has the inlet and outlet centered in the middle of the core and has adequate sized end tanks. If you can tig weld or know someone who can you can save a good bit of money on a quality intercooler by buying just the core with no endtanks and fabricate your own or buy a pre-cast piece and weld that on. Go look at atpturbo.com to see what I'm talking about.
Sometimes you can find Garrett, Bell, and PWR cores on eBay fairly cheap. That's where I found my small PWR brand new without endtanks for like 125 dollars. Bell does have fairly affordable cores to begin with. Google bell intercoolers and then go on their site and look at their air to air catalog. They give you dimensions, flow ratings, pressure drop, and price. They also have vertical or horizontal flow air to air cores and air to water cores. None of them have endtanks (and Bell gets pricey if they build them) but again if you buy a popular size then other companies will have cast endtanks you can weld on.
The other main benefit that most never consider is that the high efficiency cores offered by Garrett, Bell, and PWR are so efficient compared to the Chinese cores that you can run a much smaller core than you would need to with the Chinese cores. This is especially true with the vertical flow cores from Bell. You can run a vertical core that is literally half the size of a horizontal flow core with the same flow limits. The cost to fabricate endtanks for vertical cores will be about the same as a horizontal core. While the core might be dimensionally smaller it still takes a fair amount of material however cast endtanks are available for a large number of vertical cores as well. Treadstone offers them and you can find a good number on eBay.
Being able to run a smaller core obviously means you save money over a larger one. The smaller core means less weight (big thing if you race competitively), easier to fit which is especially useful on space limited setups, and depending on the height of the core and how it's mounted the radiator will get more ambient temperature airflow which is never a bad thing.
I strongly urge you to price out the options from the 3 companies I listed, especially in regards to Bell as their pricing has come way down in recent years and I dare say their quality exceeds Garrett in a few ways. PWR is still fairly pricey from what I can remember as I haven't checked their pricing in some time. If you get a core directly from PWR the shipping will be crazy high since they are based in Austrailia and shipping fees aren't regulated like here with the USPS if you go PWR get it from a reseller that isn't in Austrailia.
If you feel like revising your piping slightly I encourage you to look into a vertical flow core. Even if you get a vertical core from Treadstone it's still an improvement over their horizontal core and the other budget horizontal core options. I'll be using a vertical core on at least two of my high power "competition" setups.
And here I thought "I won't write a huge reply" lol.
Old Dec 14, 2015 | 03:36 PM
turbohatch96y7's Avatar
Yeah id like to see some numbers, too.
Old Dec 14, 2015 | 04:16 PM
wantboost's Avatar
Who is Mr Robot?
I believe I found flow data a while back. I'll try to find it.
Old Dec 15, 2015 | 02:48 AM
Community Builder
Im going to redo all my piping once I get a TIG welder. Its all fugly painted mild steel that was originally flux core welded way back in the day. It gets the job done but it doesnt have proper bead rolled ends either.
Old Dec 16, 2015 | 08:03 AM
Dark_Teg's Avatar
If the Treadstones do slightly lack in efficiency compared to Bell,PWR, and Garrett where Treadstone absolutely excels is in flow and pressure drop. I know people that have picked up 3 psi of boost with centrifugal blowers when they went from a Procharger/Spearco core to a Treadstone.
Old Dec 16, 2015 | 08:52 AM
Yeah were still waiting for some proof.
Im gonna keep holding my breath over here
Old Dec 16, 2015 | 03:12 PM
TheShodan's Avatar
Moderator
That's not a surprise.. Spearco had been going down hill since Turbonetics sold them in 2003. They are just above CX racing cores
Old Dec 16, 2015 | 04:31 PM
Flr Power's Avatar
It's not really about pressure but mass flow or CFM. 15 psi should have nothing to do with it. If on the other end you approach or exceed the rated CFM of the intercooler then you get higher pressure drop...
Old Dec 16, 2015 | 05:10 PM
wantboost's Avatar
Who is Mr Robot?
That's what I was getting at but couldn't find the words lol.
I've seen a few different budget intercoolers real world flow ratings didn't match the advertised flow ratings. Also I've noticed most people don't even know how to properly size an intercooler which only compounds the problem.
I'm still looking for the flow data, it's buried in my other PC.
Old Dec 16, 2015 | 05:17 PM
Flr Power's Avatar
Do you have more PC than turbo? haha
Old Dec 16, 2015 | 05:48 PM
Old Dec 16, 2015 | 08:12 PM
wantboost's Avatar
Who is Mr Robot?
lololol well I have 2 desktops with 2 hard drives each, I have around 5 or 6 laptops and 4 or 5 external hard drives. I store a lot of data, mainly white papers, SAE articles, tuning stuff, related photos, a few HDDs are movies and tv shows. I'm in the process of transferring the tech stuff over to my main PC. Some stuff I keep on a server but not having internet access except for my phone makes it impossible to reach
I just can't remember where I put the damn folder the info was in. I might be able to find it online again I hope.
Old Dec 16, 2015 | 10:09 PM
Flr Power's Avatar
That's what I thought...
Old Dec 17, 2015 | 01:43 PM
wantboost's Avatar
Who is Mr Robot?
I have the data for Bell (CFM only), Garrett (HP rating only), and Treadstone. I can't find any data for PWR. I'll make a chart showing similar sized intercoolers each company offers and their respective flow data once I get home from the dentist.
