tranny fluid question
Old Nov 26, 2007 | 01:51 PM
whoneedzvtec's Avatar
Default tranny fluid question
i just bought a new type r tranny from h motors and it has 20k only on it. i know how everybody says to use the gm syncromesh friction modified because it makes it shift so nicely and all. i want to use it but it seems as though most people use it to fix messed up syncros. im sure it has no grinds and its good condition but i want to use it because i want the tranny to shift as smoothly as possible. basically im wondering if its ok to use it on perfectly good working tranny. is this safe? thanks in advance.
Old Nov 26, 2007 | 01:57 PM
TheShodan's Avatar
Moderator
Default Re: tranny fluid question (whoneedzvtec)
Dealing with that issue on my other Type R transmission. Use the OEM MTL for the best results. My tech has been telling me that certain key components are of a different material than the other VTEC transmissions. With OEM MTL, from the dealership, we haven't had a problem yet.
Honda is one of those few companies that you can say, "when in doubt, use OEM".
Old Nov 26, 2007 | 01:58 PM
b16a4's Avatar
Default Re: tranny fluid question (TheShodan)
i use belray, its EXCELLENT
Old Nov 26, 2007 | 02:02 PM
Tippyman's Avatar
Default Re: tranny fluid question (b16a4)
I would only use Genuine Honda MTF on a low mileage or new tranny.
I use synchromesh in my tranny because it is so old and grinds like a bitch.
If it's only got 20k, then Honda MTF for sure.
Old Nov 26, 2007 | 02:18 PM
coneheadsracing's Avatar
Default Re: tranny fluid question (Tippyman)
I'd use either honda or gm. I like the gm, never used the honda MTF. The honda dealer always told me to just run 10w30 non synthetic. Never did like the way it looked when it came out. Never had issues shifting my trannies, but i've used GM synchromesh for the last 4-5 years now, and it always looks mint when i take it out.
Old Nov 26, 2007 | 08:02 PM
TheShodan's Avatar
Moderator
Default Re: tranny fluid question (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">I'd use either honda or gm. I like the gm, never used the honda MTF. The honda dealer always told me to just run 10w30 non synthetic. Never did like the way it looked when it came out. Never had issues shifting my trannies, but i've used GM synchromesh for the last 4-5 years now, and it always looks mint when i take it out. </TD></TR></TABLE>
Right, that can be done to the Other transmissions, but for Type R, being subtley different physically, I'd use the Honda MTF
Old Nov 26, 2007 | 09:49 PM
blinx9900's Avatar
i use pennzoil sychromesh on my ctr tranny, but only cause i miss shifted so bad i messed it up and the synchormesh helped take away the noise and grinding, before though all i used was honda genuine mtf.
Old Nov 27, 2007 | 07:18 AM
Muckman's Avatar
Moderator in Chief
I use GM stuff in all my cars, regardless of condition. I believe it shifts smoother and have no problems.
damasco
Oct 9, 2005 03:06 PM
EzKV
Mar 13, 2004 08:37 AM
jdmCivic925
Mar 10, 2004 11:06 AM
ProudtobeANoob
Mar 4, 2003 05:59 PM
