TPS sensor
Old Dec 8, 2003 | 10:05 PM
JR Integra's Avatar
Default TPS sensor
I am constantly getting a TPS code on my ecu...i have checked and double checked wiring..replaced the sensor .. and its still there..anyone have this happen to them? If so how did u get rid of it?
Old Dec 8, 2003 | 10:14 PM
2K_TEG's Avatar
Default Re: TPS sensor (JR Integra)
did you change anything right before you started getting the code? What did you replace the sensor with?
Old Dec 9, 2003 | 07:57 AM
JR Integra's Avatar
Default Re: TPS sensor (2K_TEG)
Well we basically had the whole engine out cause the pistons in the original block got fried. I replaced the sensor with one off of my 90 integra that never gave me problems. It seems like the TPS will never come on by itself always with the knock sensor.
Old Dec 9, 2003 | 09:22 AM
Blaze45's Avatar
Brrraaaap!
I would bet that you have the wiring of the two somehow crossed, seems that they are affecting eachother.
Blaze
Old Dec 15, 2003 | 07:15 PM
HYPERION-X's Avatar
Did you do it yourself or did you let the retards do it at Revolutions?
Old Dec 16, 2003 | 07:41 PM
JR Integra's Avatar
Default Re: (HYPERION-X)
No revolutions origonally did some of the work, but i had alot of stuff redone the block and i had a trusted mechanic do it, but mistakes couls have been made, any ideas, wires to check let me know.
Old Dec 17, 2003 | 04:11 AM
EE_Chris's Avatar
Default Re: (JR Integra)
You need a multi-meter. Check the TPS output voltage: @ idle ~.45v. You'll also want to slowly turn the TPS to make sure the output voltage sweeps smoothly.
jdmjackson
Jan 30, 2013 04:31 PM
sh!ft
May 13, 2009 01:18 PM
