torque specs for b18c
Old Nov 14, 2002 | 08:13 AM
revhardsi's Avatar
Default torque specs for b18c
anyone know the torque specs for the mains and for the girdle. Also if ur using eagle rods with arp fasteners what are those specs???? Does it make a difference if it's NA or Force inducted??
thanks
Old Nov 14, 2002 | 08:16 AM
b18bturbo's Avatar
Default Re: torque specs for b18c (revhardsi)
its 46ftl bs if i remember correctly.
Old Nov 14, 2002 | 03:51 PM
Flamenco-T's Avatar
for the main caps I believe is 46 ft/lb, the girdle is 54 ft/lb
the rods is for sure 28 ft/lb with moly lube....
might wanna check the tque amount on the caps and girdle.,..I lost my helms
Old Nov 14, 2002 | 04:13 PM
B18EG6's Avatar
I thought it was...
rod bolts 33ft/lbs
mains 56ft/lbs
girdle 49ft/lbs
thats what i gained from the helms of mine
[Modified by B18EG6, 8:16 PM 11/14/2002]
Old Nov 14, 2002 | 04:18 PM
Flamenco-T's Avatar
Default Re: torque specs for b18c (B18EG6)
yeah, that is the right nuumber for the main and girdle tqu specs..
but I'd put the rod caps at 28 with moly lube.....I might have done mine at 30, a median numbers...
stan
uberEFtuner
Feb 1, 2015 10:39 AM
Civic483973
Jul 10, 2010 08:39 PM
I8ayellowcrayon
Jan 16, 2005 12:00 AM
B18C5-EH2
Feb 14, 2004 03:58 PM
B18C5-EH2
Feb 14, 2004 09:05 AM
