Torque spec for b18c oil pan?
Old May 18, 2002 | 01:14 PM
yellow blur's Avatar
Default Torque spec for b18c oil pan?
just finished tapping the oil pan and i need to put it back, does anyone know the torque spec for a b18c motor? thanks.
Old May 18, 2002 | 02:00 PM
VaporTrail's Avatar
New User
Default Re: Torque spec for b18c oil pan? (yellow blur)
10 ft/lbs
Old May 18, 2002 | 04:21 PM
sgT's Avatar
sgT
Default Re: Torque spec for b18c oil pan? (VaporTrail)
108inlbs
Old May 18, 2002 | 06:31 PM
1fstevo's Avatar
New User
8.5 foot pound.
Old Jun 5, 2011 | 04:14 PM
typerwhat's Avatar
The honda manual shows that the torque specification for the oil pan on the b18c is 9 ft lbs. Even when installed the myHondaHabit oil pan gasket and stud kit they recommended the 9 ft lbs of torque on the nuts. If you doubt it, check the manual or see the specs at www.myhondahabit.com
If you got to 10 ft lbs, your are increasing the torque by 1/10th of the recommended amount... I wouldn't.
Old Jun 5, 2011 | 04:28 PM
rich7777's Avatar
Thats a bit over the top. For a start i bet no one has a torque wrench thats capable of giving you smack on 9 ft lbs. I always do them hand tight and have never had a problem. I have a good feel with bolts though.
Old Jun 5, 2011 | 04:46 PM
DC4KiD's Avatar
I have one, and I'm more than sure there are plenty others out there that have them as well.
Old Jun 5, 2011 | 04:52 PM
rich7777's Avatar
There never smack bang on what you set them to though. They'll always be +-X% out.
What i'm trying to get at is 1 ft lbs isnt going to be the end of the world.
Old Dec 22, 2011 | 04:37 AM
criticallistenp's Avatar
I have a Snapon torque wrench that is dead on. I've built 3 motors with it. I can get the 9 lb ft mark with no problem. Now, if you are going to Harbor Freight for your torque wrench, good luck. I have one of those too. That's how I decided upon getting the Snapon.
Typerwhat is right - 10 lb ft is an 11% increase over the recommendation, and when it comes to torque, that is massive, well outside what a good torque wrench's margin for error is. The biggest issue with this is that the oem gasket can't handle 10 lb ft properly without tearing and the oil pan is stamped steel so it bends at the bolt holes when they are overtorqued, causing an uneven sealing surface for the gasket. That spells leaks as many of us know. The OEM oil pan is super sensitive to torque. That is probably why the myhondahabit gasket calls for the same torque specification. Their gasket will take more torque, but the pan won't.
Old Dec 22, 2011 | 04:54 AM
Turbo-LS's Avatar
you really dont need a torque wrench on oil pan bolts. use a 1/4 drive socket and just make them snug.
Old Dec 22, 2011 | 05:14 AM
BigMike0147's Avatar
critical said it right....
I went by the book with my last build for the torque spec and it ended up ripping the gasket!! That's the ONLY thing I've come across like that in the manual. Now all I do is tighten the fasteners and watch for the gasket to squeeze away from the pan slightly. All this is also working from the "center" bolts and criss-crossing my way outward. I haven't had an issue since doing that.
Old Dec 22, 2011 | 05:33 AM
rich7777's Avatar
Thats exactly what i think still. There is no need to be totally **** about them. Just don't get using a bar to tighten them up lol.
elchapin
Nov 27, 2009 05:55 PM
NewtwoHondas
Jun 25, 2006 04:20 PM
JDubya
Jun 9, 2004 03:11 PM
XRatedGSR
Feb 8, 2003 09:54 AM
prjctCIVIC
Sep 1, 2001 09:53 PM
