torque converter (higher stall)
Old Feb 5, 2002 | 08:16 AM
NXAccordTO4B's Avatar
Default torque converter (higher stall)
Hey guys (and girls) can someone help with a problem, this is my situation:
I am building up my f22b1 motor (pistons, rods, valves, springs, etc.....) to handle about 15 pounds of boost, my problems is that I will have a lag off the line with my turbo since my car is an auto, so im putting a 75-100 of NOS to get me off the line. Do you think is should just get a higher stall for my Torque Converter from level ten or just run the NOS, or both. If so at about with rpm should my stall be?
thanks
Old Feb 5, 2002 | 03:22 PM
forcefed's Avatar
Default Re: torque converter (NXAccordTO4B)
both, but my real suggestion you already know
ditch the tranny, i did and will never look back. that is probably the weakest
tranny that honda makes. Way back when i had my accord stock (with auto)
i had a 75 shot, i/h/e,and tb. i went through 3, thats right 3 tranny's in 1 year,
save yourself the trouble, hassle, and money, and switch it's really preaty easy
did it myself in a weekend. plus the enjoyment factor quadruples and thats what you are realy after, right
my .02
Old Feb 6, 2002 | 06:55 AM
Default Re: torque converter (forcefed)
did u mean switch to a manual or change out the Torque converter
thanks
Old Feb 6, 2002 | 08:37 AM
rtype11's Avatar
If you could get an auto tranny like the ZF for vettes you will be laughing at us all, the problem is that I dont even think level 10 can make a strong enough high stall converter, not ever using one I would speak with their tech guys about a 4500 stall.
Old Feb 6, 2002 | 08:42 AM
b18bturbo's Avatar
Default Re: torque converter (rtype11)
i mean if the neon can do it i dont see why a honda cant do the same. Its pretty much how the build valve bodies as well as your converter. Everyhting inside is gonna need toget upgraded. I would take to somone like level 10 and discuss your application with them. Anyone with money can get anything done.
Old Feb 6, 2002 | 01:42 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
we only have 1/8th mile locally...my car was a auto turbo hybrid hatch...stock ls motor, tranny, turbo kit (6 psi) and i was getting 8.5-8.7 all day and night. 2.1 60's on 175/70/r-13 stock wheels and tires!...auto is very consistent and though no one liked it, i did. everyone in this town respects me becaause my car auto was working all the mild tt cars (supras, vr4's, z's) corvettes. with the manual, my car is a sec slower average because of wheelspin though i have that taken care of but haven't retimed yet. i am trying to say that having raced both...i want another fully built motor and built auto tranny hatch. just for racing but that won't happen anytime soon. just costs about a grand for level ten to 'bullet proof' your tranny and the converter is another $500-600 bucks. i say if you had a lighter car it would be worth it but honestly i don't think you can have a fast heavy auto car. you'll spend sooo much building a high horse motor to move the weight. good luck whatever you do.
Old Feb 6, 2002 | 09:30 PM
RH+G's Avatar
At 15 lbs of boost you will need to get your tranny Level Ten Rebuild. A convertor alone will not do
Old Feb 7, 2002 | 07:11 PM
Default Re: torque converter (RH+G)
cost too much to get level ten to rebuild tranny around $4000.00
Old Feb 7, 2002 | 09:01 PM
RH+G's Avatar
Buy the level ten kit take it to tranny shop to get rebuild and get the convertor built whilke the tranny is being rebuilt and you have a built tranny good for about 350-400 at half the cost
Old Feb 8, 2002 | 08:48 AM
thanks i went around and call all my local shop and other place, they like to BS me around, no one here wants or have the know how to build my tranny. I wanted to do that but I dont trust anyone near me.
Old Feb 8, 2002 | 09:00 PM
RH+G's Avatar
Where do you live?
Old Feb 11, 2002 | 08:01 PM
South Mississippi, (Gulfport)
Old Feb 11, 2002 | 08:37 PM
RH+G's Avatar
Oh. Well in reality any shop that rebuilds trannys can and should do it for you. Up in NY we have plenty. Alot of times it is the smaller shoips that rebuild the tranny right there and then while the larger ones send it out to be rebuild
Old Feb 11, 2002 | 11:32 PM
csufweed's Avatar
you can always get the shiftronic kit by levelten... over $1000 and it should be shifting faster than a manual.
I personally have been able to get quite a bit of power from my auto... but the auto has sucked for a long time now. I'm probably gonna buy the rebuild kit and try to do it myself... if i can't then its off to a local shop. I would like to get the works, but thats gonna be a while... about 2G's for everything, not including labor.
Im personally just working out all the kinks in the engine first, then i'll worry about the tranny later. I figure its good enough and I'm not really racing right now and if i am low 14's will do the trick a lot of the time. Ever check that AAMCO place? Supposedly cheap... just buy the parts and have them rebuild it with the levelten parts.
Old Feb 12, 2002 | 12:23 AM
Default Re: torque converter (csufweed)
thanks guys for all u info, hopefully I figure it out soon my motor is coming back to me in about 2 weeks or so.
tuco_ruiz
Jul 29, 2002 04:43 PM
NXAccordTO4B
Feb 7, 2002 07:27 PM
Duck Sauce
Nov 10, 2001 12:31 PM
Integra187
Oct 24, 2001 07:53 PM
