Top Mount Manifolds
Old Jul 3, 2005 | 05:10 PM
LSEGHATCH's Avatar
Default Top Mount Manifolds
I've noticed that top mounts are the new ram horns, but are they as efficient? A couple months back I was planning on buying my equal length ramhorn but due to funds wasn't able to. I am beginning to think that I got lucky since now I have the option to pick up a top mount. A couple questions first:
1) Are they as efficient as Equal Lenghts
2) What does the pricing run
3) When going the top mount rout, are there more things to take into consideration w/ the rest of the turbo setup?
Also any pics of your top mounts would be
Old Jul 3, 2005 | 05:28 PM
stealthmode62's Avatar
Default Re: Top Mount Manifolds (LSEGHATCH)
I've noticed the popularity as well. I would guess that the runners are about the same length, just that one goes one way and one goes the other.
I'd like to hear from top mount users on how many inches of drain line they are using.
96ex's Avatar
https://honda-tech.com/zerothread?id=1260769
There's the top mount that I just purchased. It should allow for better oil return seeing there is a nice 10 inch drop or so to the pan. The only problem I'm going to have is where to route the intake to (stupid ford housing flanges on my comopressor).
Old Jul 4, 2005 | 02:51 AM
VRD^sam's Avatar
Default Re: Top Mount Manifolds (96ex)
this is the shitz
Old Jul 4, 2005 | 06:04 AM
ah789454's Avatar
Default Re: Top Mount Manifolds (RHD_EK9)
can someone tell me how they run the oil lines when they have the turbo on top
Old Jul 4, 2005 | 06:29 AM
hondaguyef's Avatar
Default Re: Top Mount Manifolds (ah789454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ah789454 &raquo;</TD></TR><TR><TD CLASS="quote">can someone tell me how they run the oil lines when they have the turbo on top</TD></TR></TABLE>
Same as when the turbo is on the bottm . Clock the center section so that the feed is on top and run a longer return line.
Phil
Old Jul 4, 2005 | 06:35 AM
done's Avatar
Default Re: Top Mount Manifolds (hondaguyef)
LOVEFAB
GRANTEED to hold boost!!
Old Jul 4, 2005 | 07:57 AM
dornon13's Avatar
Default Re: Top Mount Manifolds (Jordo@KAP)
I have always wondered if the hood would get incredibly hot and ruin the paint. I have been thinking about making one for my D
Old Jul 4, 2005 | 08:28 AM
done's Avatar
Default Re: Top Mount Manifolds (dornon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">I have always wondered if the hood would get incredibly hot and ruin the paint. I have been thinking about making one for my D </TD></TR></TABLE>
gets hott, but mine is fine
Old Jul 4, 2005 | 09:24 AM
mrbsponge's Avatar
in that last pic, it looks like that wastegate design is awesome, with the flow of exhaust gasses! i might have to get on eof these things now!
Old Jul 4, 2005 | 09:32 AM
done's Avatar
https://honda-tech.com/zerothread?id=1289635 if you wanted a ram horn.. i need it sold
BTW: I can get lovefab products!! http://www.kohlerperformance.com
Old Jul 4, 2005 | 10:05 AM
BBPEG6's Avatar
can you keep a/c with that m/f?
Old Jul 4, 2005 | 10:38 AM
scoop's Avatar
https://honda-tech.com/zerothread?id=1012591
Old Jul 4, 2005 | 11:15 AM
PHiZ's Avatar
Default Re: Top Mount Manifolds (scoop)
I think one benefit is that it makes it a no-brainer to run a down-hill oil drain.
-PHiZ
Old Jul 4, 2005 | 11:16 AM
01civicex's Avatar
i like the top mount manifolds alot
Old Jul 4, 2005 | 01:43 PM
Odiedogcx's Avatar
AIRBORNE
CRP has had one out for quite a while now, and he's been selling quite a few of them. This is my friends, i believe the first top mount CRP made, and i also think CRP made one of the first top mounts .. but dont quote me on that.
Old Jul 4, 2005 | 04:36 PM
turbotommy's Avatar
Default Re: Top Mount Manifolds (Odiedogcx)
most top mount manifolds retain the "equal length" runner design. the top mount design also allows for use of a larger diameter downpipe (3.5"-4"). if you go with a topmount mani your most likely gonna need a trick intake system or c-clamp some wire mesh to the turbo inlet, a longer oil return line and a half radiator (most designs dont clear a full size).
this full-race product is amazing...
online store info...
http://www.full-race.com/catal...d=317
Old Jul 4, 2005 | 05:04 PM
june's Avatar
Default Re: Top Mount Manifolds (turbotommy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotommy &raquo;</TD></TR><TR><TD CLASS="quote">most top mount manifolds retain the "equal length" runner design. the top mount design also allows for use of a larger diameter downpipe (3.5"-4"). if you go with a topmount mani your most likely gonna need a trick intake system or c-clamp some wire mesh to the turbo inlet, a longer oil return line and a half radiator (most designs dont clear a full size).
http://www.full-race.com/catal...d=317</TD></TR></TABLE>
It is amazing when you have one in your hand.
Old Jul 4, 2005 | 05:07 PM
Tchleung's Avatar
All my pics and short review are in my thread here:
https://honda-tech.com/zerothread?id=1217853
The return line is prolly about 12" lnog or so. it's sucha fail safe easy way to reoute the return line that no noe could mess it up.
Tchleung's Avatar
Here's a more recent pic on the dyno.
Old Jul 4, 2005 | 05:17 PM
tepid1's Avatar
Here is mine... Loving every bit of it!
Old Jul 4, 2005 | 06:12 PM
turbotommy's Avatar
Default Re: Top Mount Manifolds (june)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by june &raquo;</TD></TR><TR><TD CLASS="quote">
It is amazing when you have one in your hand. </TD></TR></TABLE>
or seeing it on geoff's car every day i go to work
Old Jul 4, 2005 | 07:58 PM
ScottEK's Avatar
Old Jul 5, 2005 | 01:18 AM
Flamenco-T's Avatar
Default Re: Top Mount Manifolds (ScottEK)
to answer your question,
I saw a better gain in response and spool up with the top mount
One-Fab Top mount starts at $ 850, Let me know if you are interested
[b] Oil return kit must be longer, about 12 inches or so. No AC, no P/S and a little extension for the intercooler piping.
Now, for fun....try this one
One-Fab top mount manifold and Jason "St00pid" 4" downpipe.
the above turbo is a T3/4E
stan
Old Jul 5, 2005 | 09:12 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: Top Mount Manifolds (Flamenco-T)
my god....^^^...did u make that screen cap on that 42R? ive never seen that.
