too low compression for tune??
Old Jul 3, 2007 | 05:47 PM
teddy_dc2's Avatar
Default too low compression for tune??
recently my car (b18c turbo) has been feeling weak. runs relative fine but it feels like the car is losing power. it running a crome pro basemap 7psi on p28. i was thinking of tuning it but i just did a compression test earlier can came up with about 160psi all across and with oil 190psi all across. before the test without oil ran: cyl1&4:200, cyl2&3:190. should i invest in on a rebuilt or will the tune be a better choice..
Old Jul 3, 2007 | 05:50 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
Default Re: too low compression for tune?? (teddy_dc2)
thats fine, with the compression test you are looking for difference in compression between cylinder, rather than just high numbers. 160 even across is just fine. Get it tuned!! A base map is intended for you to get the car running healthy before you take it to the tuner, that means no leaks no bs, but a base map is not optimized for your settings, and in most cases unsafe to beat on.
Old Jul 3, 2007 | 07:44 PM
bigbadboy's Avatar
i would do a leakdown test as well. i would invest in a good rebuild kit since you are losing comp on all your cylinders
Old Jul 3, 2007 | 08:33 PM
building boost's Avatar
did you hold the throttle down while cranking? if not, that's why your comp is 160.
Old Jul 4, 2007 | 07:43 AM
teddy_dc2's Avatar
Default Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">did you hold the throttle down while cranking? if not, that's why your comp is 160.</TD></TR></TABLE>
never thought of that. back in fall i did the test and got high numbers, now nearly a 30psi drop. the car is @ 152,000 miles so i don't expect much. i guess i'll just get it tuned @ 7psi for now. i baby the car and barly beat on the damn thing. I'll try another test with open throttle if it makes a difference.
Old Jul 4, 2007 | 07:50 AM
teddy_dc2's Avatar
will this low of a compression effect the power if tuned say like making less power?
76 camaro car
Apr 20, 2017 04:47 AM
climb_on
Jul 29, 2007 03:40 PM
John.
Jun 12, 2006 08:45 AM
Azcheron
Jun 23, 2005 09:34 PM
SPOON_FED_DC_2
Apr 6, 2005 09:19 PM
