TOO long rod & piston set?
Old Oct 15, 2002 | 12:50 PM
jesselee's Avatar
Default TOO long rod & piston set?
Anyone has the scoop on these? Or is it still in the vaporware stage?
http://www.theoldone.com/components/pistons/
Go to the bottom of the page. These are pistons w/ pins moved up. Supposed to allow you to fit a +0.137" longer rod into a standard height b18 block.
Old Oct 15, 2002 | 12:51 PM
SiRkid's Avatar
Default Re: TOO long rod & piston set? (jesselee)
Old Oct 15, 2002 | 01:12 PM
BudaKai's Avatar
Default Re: TOO long rod & piston set? (SiRkid)
That little bit of an increase on the rod is not going to do much, but I guess every little bit helps. Those are some very nicely designed pistons though. Why don't you just contact them and let us know too.
Old Oct 15, 2002 | 01:37 PM
filetofit
Guest
Posts: n/a
IM me I got some custom JE's 81mm bore, 20mm wristpin, 0.940 center to top height, 9.0 CR I'm looking to sell.
1320london
Engine Machining & Assembly
Sep 6, 2016 01:32 PM
SLIM NOTHING
Jun 7, 2011 08:03 PM
LS/V-T
Jan 5, 2011 09:19 AM
Yuleluder
Feb 15, 2006 05:14 AM
edo
Jul 15, 2005 09:16 AM
