Too Large of a Snail?
Old Jun 7, 2007 | 04:48 AM
EX-T's Avatar
Default Too Large of a Snail?
I have a built d16y8 with the trusty old vitara/eagle combo yielding a compression ratio of 8.6:1. I have a Garrett t3 with a .48 exhaust and .50 compressor. I have the chance to trade straight up for a Turbonetics t3/t4 with a ~.60 exhaust side (it's on a buddies rb20det and he's not sure what the a/r is on the hot side) and even bigger compressor side.
Would my D be able to spool the Turbonetics?
Old Jun 7, 2007 | 06:59 AM
twkdCD595's Avatar
Default Re: Too Large of a Snail? (EX-T)
t3/t4 with .60? are you saying it a 60 trim, cause you say he does not know the exhaust housing a/r so? is all the information you have?
can you get more specs... cause it could be quite a few different turbo's from that description. most of which will probably spool on a d series, the question would be when though.
need more information... if the guy does not know what he bought (which is pretty dumb but whatever) then see if you can look at it and get all the information to you can figure out from looking at the housings, chra, serial plate, etc.
Old Jun 7, 2007 | 07:02 AM
EX-T's Avatar
C'mon, someone knows!
Old Jun 7, 2007 | 07:08 AM
agrn93ls's Avatar
well.... to answer the exact question you asked, yes your D series will spool that turbo.
Old Jun 7, 2007 | 07:47 AM
EX-T's Avatar
Default Re: Too Large of a Snail? (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">t3/t4 with .60? are you saying it a 60 trim, cause you say he does not know the exhaust housing a/r so? is all the information you have?
need more information... if the guy does not know what he bought (which is pretty dumb but whatever) then see if you can look at it and get all the information to you can figure out from looking at the housings, chra, serial plate, etc.</TD></TR></TABLE>
He's not 100% sure if it's .60 A/R for the exhaust side but that's what he thinks it is.
I tried looking at it but it's on the car and it was dark when I was looking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">well.... to answer the exact question you asked, yes your D series will spool that turbo.</TD></TR></TABLE>
I know my D will spool it but when? Roughly?
Old Jun 7, 2007 | 08:59 AM
SovXietday's Avatar
Around 5Kish, turbo's good for 450+.
s1ngle
Jun 9, 2005 04:44 PM
b_series_boy
Oct 24, 2004 10:31 PM
ludelvr
Oct 22, 2002 10:05 PM
