Toluene???
Old Feb 15, 2003 | 11:19 AM
TurboedGSR's Avatar
Default Toluene???
How many of you use it? Any cons/bad effects with long term use on a daily driven car. I plan to run a 95-96 mix on every refill...bad?
it just sounds too good to be true
Old Feb 15, 2003 | 11:30 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Toluene??? (TurboedGSR)
what is it? and how do you know how much to add? how much does it cost and where do you get it? up cause I wanna know
Blaze
Old Feb 15, 2003 | 11:52 AM
TurboedGSR's Avatar
Default Re: Toluene??? (Blaze45)
sold at your local sherwin williams. 114 octane. $8-10 for 1 gallon, $5-8/g for 5 gallons, <$5 for 55 gallon drums.
I work at a paint shop so i get a better price.
I figured 10 galllons mid grade + 2 gallons toulene. close to 95 mixture. I could live with $6 extra every fill up
Old Feb 15, 2003 | 12:52 PM
DIRep972's Avatar
Smarter than you
My friend runs ghetto race gas(toulene mix) in his supra daily. It works great for him, but those cars have factory knock sensors. I'd be scared of having an inconsistancy w/ the toulene mixing. are u planning on running more boost/timing then 93 octane will allow?
Old Feb 15, 2003 | 12:55 PM
Mase's Avatar
Default Re: Toluene??? (DIRep)
I myself, am thinking about brewing up some....once i get a GM Knock Sensor.
Old Feb 15, 2003 | 03:27 PM
TurboedGSR's Avatar
what could go wrong, how could it be inconsitant?
i dont plan to run insane boost levels. just want extra security for my untuned motor. The higher the octane>less chance of detonating>more timing, correct? so i can raise the boost a little more and not worry about stock timing
just went to sw and bought a gallon (8.95) and poured it into 7gal. of premium. havent ran the car long enough for the new mix to take effect, but i'll post later
Old Feb 15, 2003 | 03:32 PM
DC2Slow's Avatar
what brand or name is it under do just ask for Toluene?
Old Feb 15, 2003 | 03:33 PM
Sonny's Avatar
Default Re: Toluene??? (zetarider)
Good luck finding it in California. I used to use toluene/diesel fuel as a tire softener, but it is very very hard to get toluene here now.
Sonny
Old Feb 15, 2003 | 03:39 PM
swrdply400mrelay's Avatar
Default Re: Toluene??? (Sonny)
I used to work for an aircraft company in the hangars and they had drums of that stuff. If only I had known 3 years ago......
Old Feb 15, 2003 | 03:49 PM
TurboedGSR's Avatar
easy to get here, lowes and home depot also carry it. the only had 1 gallon containers, 5/55 are special order.
tire softener? would this work for any tire
Old Feb 15, 2003 | 04:00 PM
danl's Avatar
Banned
I run it in my dsm. It works great. Consider it unleaded race gas. DOn't go over 30% in your gas though or your car will have a bad idle because it doesen't like to burn at low temps. It is like 114 octane. A 30% mixture with 94 octane pump gas puts me easilly over 100 octane, without the lead. Its perfecly safe, and is actually found in pump gas anyways. Xylene also works great, but has less BTU than toulene. I find that xylene works better for boosted engines, keeping EGT's down just a little more because toulene burns a little hotter. Whatever works though. I typically run 2 psi more boost at least with xylene or toulene, with simillar knock counts on my logger. Just be sure to add 2-3 ounces of 2 stroke motor oil or something to lubricate your fuel pump a little or your'll burn it up.
Old Feb 15, 2003 | 04:03 PM
boosted3g's Avatar
Default Re: Toluene??? (danl)
you can also use MTBE which is also found in pump gasoline. It is far more easily obtainable.
Old Feb 15, 2003 | 04:15 PM
zip's Avatar
zip
Sonny used it for professional Kart racing.
Old Feb 15, 2003 | 04:36 PM
DIRep972's Avatar
Smarter than you
probably nothing but when mixing gas and chemicals I just wonder if things always mix perfectly.
Old Feb 15, 2003 | 04:57 PM
Quick 200k Mile Motor's Avatar
Ive used toluene, but everywhere I go xylene is more obtainable.
Would there be any difference using xylene?
Old Feb 15, 2003 | 05:11 PM
seekerONE's Avatar
homebrew gasoline mixtures....this has been covered before...check this link
http://www.vtr.org/maintain/gasoline-octane.html
ignore this prices it shows...this is an old article.
Old Feb 15, 2003 | 06:58 PM
underpressure02's Avatar
We run it in our S4's and so do a bunch of guys on Audiworld. I do not think it causes any harm well at least not yet.
Old Feb 15, 2003 | 07:12 PM
Tinker219's Avatar
Default Re: Toluene??? (underpressure02)
Looks like I found a way to effectively/financially daily drive with higher boost on my high compression
Old Feb 15, 2003 | 09:33 PM
Stu's Avatar
Stu
New User
Default Re: Toluene??? (Tinker219)
In "Maximum Boost" by Corky Bell, hes says that in 1987, the Formula 1 guys were running toulene and running 75+ pounds of boost!!!!!!! Also, just an FYI, toulene is the second "T" in TNT.
Old Feb 15, 2003 | 09:40 PM
shortyz's Avatar
Default Re: Toluene??? (Stu)
yep toulene works great.
alot of snowmobilers use it in with 94 octane u can get here.
Old Feb 15, 2003 | 10:51 PM
AccidentproWn's Avatar
you can put toluene in with your gas? i didn't know that... very interesting my dad is a chemist so i can steal some from his lab
Old Feb 16, 2003 | 07:16 AM
filetofit
Guest
Posts: n/a
Sonny
THat's becuase all your trailer park types out here in California pore it on rags and huff the vapors. It gets you high. Also the solvent in spray paint.
Old Feb 16, 2003 | 01:45 PM
UberTeg's Avatar
Default Re: Toluene??? (filetofit)
Sonny
Did they outlaw elmers too? And i'm sure you could get high off regular gas vapours too..
Old Feb 16, 2003 | 02:28 PM
bruthaboost's Avatar
Default Re: Toluene??? (AccidentproWn)
That toluene is probably ACS grade or better and very expensive
Old Feb 16, 2003 | 03:14 PM
boosted92's Avatar
It gets to be a bit of a pain in the *** though. Alky/water or propane is as effective as running about 104 octane, and propane is a lot cheaper. A lot of the GN guys use it.
