TODA Spec D's + NOS??????
Old Jul 2, 2003 | 12:56 PM
speedyonez's Avatar
Default TODA Spec D's + NOS??????
i just got an ericks racing 2.0 setup i wanna spray it.... 13:1 pistons and toda spec d's anyone know if this will work??????
Old Jul 2, 2003 | 01:02 PM
speedyonez's Avatar
some one help me!!
Old Jul 2, 2003 | 03:05 PM
shadyCTR's Avatar
Default Re: (B19c5-eg6)
just do it, I'll be doing a 2.1 all motor than juicing in a couple months!
Old Jul 2, 2003 | 04:10 PM
MaxBoost's Avatar
New User
Default Re: (shadyCTR)
Swap out the cams b4 you spray. too much overlap on those specD's will let the nitrous go in one valve and out the other. Also with compression that high use high octane gas only, tune the car "on nitrous", be careful with timing, and keep the nitrous shot semi conservative...
Old Jul 2, 2003 | 04:13 PM
Al Bundy's Avatar
Default Re: TODA Spec D's + NOS?????? (B19c5-eg6)
Its nitrous, not NOS. Sorry thats my petpeeve
Old Jul 2, 2003 | 04:16 PM
done's Avatar
Default Re: (MaxBoost)
toda d = tons of overlap
Old Jul 2, 2003 | 05:29 PM
speedyonez's Avatar
what about jun stage 3's?
Old Jul 4, 2003 | 02:45 PM
speedyonez's Avatar
how come you can spray skunk stage 3's but not toda spec d's?
Old Jul 5, 2003 | 11:32 AM
2 0 3's Avatar
you can spray whatever you want to spray, fact of the matter is, although you will still make more power, till will not nearly be as much as if you used a cam with a shorter duration.
Spraying on all motor cam wont do damage, ill will just dump all the nitrous right out the exhaust valve before making power. i would recommend a Turbo style cam. with this you still have a high lift, but the duration isn't so long. Good Luck
People_Mover
Dec 14, 2008 02:16 PM
GOLDBERG
Aug 10, 2003 04:08 PM
blykins
Apr 19, 2003 08:51 AM
JDM DC2 R
Apr 9, 2002 03:42 AM
Pinhead
Jan 31, 2002 10:48 AM
