Timing problem with hack
Old Jul 19, 2003 | 05:20 AM
NOSED_CRX_VTEC's Avatar
Default Timing problem with hack
Can someone please explain why the Vafc alters the timing.
I cant see why it does it.
Thanks
Old Jul 19, 2003 | 09:22 AM
sharkcohen's Avatar
Default Re: Timing problem with hack (NOSED_CRX_VTEC)
A drop in MAP voltage normally is associated with an increase in engine vacuum. The ecu is programmed to respond to this by advancing the timing. When using the hack, you are artificially reducing the MAP voltage to run larger injectors and prevent the ecu from "seeing" boost.
BoostedD15B7
Feb 29, 2004 04:23 PM
ELSpool
May 2, 2003 11:35 PM
BlueSi2k
Nov 18, 2002 01:31 PM
cjblmr
Nov 12, 2002 06:41 AM
GReddyB18C
Sep 7, 2002 05:24 PM
