timing and hondata....
Old Jan 16, 2003 | 05:09 PM
BoostedH23a1's Avatar
Default timing and hondata....
well as u know i have a prelude.. anyway i have an aftermarket flywheel which does not have the timing mark... i was wondering what the deal is gonna be when i get my hondata.... will the tuner be able to tell what degree my timing is at?
Old Jan 16, 2003 | 05:50 PM
Flamenco-T's Avatar
Default Re: timing and hondata.... (BoostedH23a1)
huh ?
Old Jan 16, 2003 | 05:55 PM
boosted hybrid's Avatar
Default Re: timing and hondata.... (Flamenco-T)
Exactly what i was thinking when i read this post. I think he means the crank pully.
Old Jan 16, 2003 | 06:34 PM
DeepSi's Avatar
Default Re: timing and hondata.... (boosted hybrid)
What does the flywheel have to do with the timing? I believe you can see and set the timing in the Hondata.
Old Jan 16, 2003 | 06:52 PM
Flamenco-T's Avatar
well, if you have an aftermarket crank pulley, then insert the crank pulley to the end of the crank shaft, insert the key, then set the piston #1 at TDC..
install the lower timing cover, then mark the crank pulley by the notch on the timing cover with a white out or anything to mark it permanently
stan
Old Jan 16, 2003 | 07:34 PM
guys guys.. preludes dont have timing marks on the crank pulley..
Old Jan 16, 2003 | 07:42 PM
HotRodTeg's Avatar
he right the preludes use there flywheel to set tdc and there cam gears. What after market flywheel do you have? It should have a mark or you could make your own before you installed the flywheel. lates
Old Jan 16, 2003 | 08:30 PM
Default Re: timing and hondata.... (streetracer)
little late for that...
its an ACT one from back in the day
Old Jan 16, 2003 | 08:34 PM
boomslang's Avatar
If you have a TDC mark on your flywheel, then you can figure out the timing with one of those advancing timing guns. Without the TDC mark, you are SOL.
Flamenco-T's Avatar
Oops, sorry, I haven;t worked on any H series motor yet...
how can you see the flywheel though ?
I mean do youhave to take out the starter before you check your timing ?
Old Jan 16, 2003 | 10:41 PM
damnit.. what about all those numbers on the hondata screen.. wtf are those
Old Jan 17, 2003 | 02:28 PM
up
Old Jan 17, 2003 | 02:54 PM
sgT's Avatar
sgT
every flywheel i have seen so far has at least 1 mark.
you have to find the right timing light. If it has tdc mark a craftsman
advancing light can help.
Old Jan 17, 2003 | 07:27 PM
Default Re: timing and hondata.... (sgT)
its a stock regrind... they ground off the mark
Old Jan 18, 2003 | 12:28 AM
sgT's Avatar
sgT
set the motor to tdc and paint a mark maybe
Old Jan 18, 2003 | 05:33 AM
that wouldnt work.. it could be at 2 degrees it could be at 20..
dvp95
Aug 21, 2003 07:45 AM
civbeater90
Nov 16, 2002 12:46 PM
89JDMcrx
Sep 25, 2002 05:22 PM
boomslang
Nov 30, 2001 06:48 AM
bgod
Jul 23, 2001 06:37 AM
