timing belt
I got type r belt. but when i put it on i can't get the crank to line up. i try it like 20 time and it allways off one thoth
its my b16b block with gsr crank and the block was sleeved.
p.s and skunk 2 cam gears
its my b16b block with gsr crank and the block was sleeved. p.s and skunk 2 cam gears
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr83 »</TD></TR><TR><TD CLASS="quote">would decking the block make it always one tooth off?? because i think thy do that after sleeving it.</TD></TR></TABLE>
Sure, it can set it off, but i dont know if a whole tooth,
is this how i should do it, bring the engine up to TDC. There are 5mm dowel holes in the cam cap cover and camshafts. Stick 5mm dowels into both the intake and exhaust camshaft. Loosen the cam gear bolts. Turn the crankshafts in the direction the engine rotates a few teeth, than bring it back to TDC again. Tighten the cam gear bolts. This brings the cams back to TDC with the crankshaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr83 »</TD></TR><TR><TD CLASS="quote">is this how i should do it, bring the engine up to TDC. There are 5mm dowel holes in the cam cap cover and camshafts. Stick 5mm dowels into both the intake and exhaust camshaft. Loosen the cam gear bolts. Turn the crankshafts in the direction the engine rotates a few teeth, than bring it back to TDC again. Tighten the cam gear bolts. This brings the cams back to TDC with the crankshaft. </TD></TR></TABLE>
Except for that rotating the crank part. Get the crank at TDC, lock the cams with the dowels, then put the belt on it, adjusting the cam gears as necessary to make it fit.
Decking the block and head normally only takes a few thousandths of an inch off of each, not enough to put your cam gears way off.
Metal Head
Jul 24, 2008 03:00 AM
cyrix12
Jan 6, 2006 12:37 AM
