timing
Old Apr 9, 2003 | 09:06 PM
hollaback6's Avatar
Default timing
umm...right now i am running a t25 at 11 psi with an afc and dsm injectors. We retarted the timing back 6 degrees. Do you think i could pull a little more timing out of this? We haven't got it fully tuned but the egts are only at like 1300 degrees. thank
Old Apr 9, 2003 | 09:17 PM
Flamenco-T's Avatar
Default Re: timing (hollaback6)
I used .7 degrees per psi, static timing since I haven't put the hondata on
stan
Old Apr 9, 2003 | 09:42 PM
hollaback6's Avatar
oh yeah i have another question i forgot to ask. We were tuning it last night and my check engine light kept on showing up. It is at 11 psi as i have stated. Everybody told me to lean it out more and the light won't turn on. My question is will it run too lean? I was probably going to have settings around -40
Old Apr 9, 2003 | 10:06 PM
Flamenco-T's Avatar
what was your cel code ?
Old Apr 10, 2003 | 12:28 PM
hollaback6's Avatar
umm...i have know idea. It just said check engine.
Old Apr 10, 2003 | 01:01 PM
intekragsr's Avatar
pull the service connector and jump it with a paper clip and read the blinking lights. http://www.team-integra.net has a good write up on how to read codes.
Old Apr 10, 2003 | 01:02 PM
SOUNDEFFECTS's Avatar
Default Re: timing (intekragsr)
stock map sensor maybe?
Old Apr 11, 2003 | 02:05 PM
hollaback6's Avatar
well it turns out i just have to lean it out more. I have it at 50% just about all the way across on high and low throttle and it is still running rich.
iponnet
Mar 16, 2011 05:33 PM
TeamCracka
Jul 2, 2004 04:37 PM
BoostedD15B7
Mar 2, 2004 10:20 PM
fso_BamBam
Aug 21, 2001 01:50 PM
