Tilton clutch kit!
Old May 23, 2004 | 09:19 AM
done's Avatar
Default Tilton clutch kit!
The 7.25 kit with flywheel, if im reading it correctly off of the titlon site, it says is a 6lb fly wheel. THAT SUCKS HORRIBLLY, if i would have known that i wouldnt have gotten it.
http://www.wiredspeed.com/Item...q=&Tp=#
is that gonna be WAY to light for my boosted app..!!!
Old May 23, 2004 | 09:30 AM
SOUNDEFFECTS's Avatar
Default Re: Tilton clutch kit! (Jordo)
Does everyone on here use the rally version or the other on that is 8in+?
Are all the tilton 7.25 pressure plate the same? Thats how tilton lists them and I'm curious if they are used on other applications.
Old May 23, 2004 | 10:20 AM
94gsr4dr's Avatar
Default Re: Tilton clutch kit! (SOUNDEFFECTS)
yikes, that is pretty light.
Old May 23, 2004 | 10:25 AM
el arbi's Avatar
Default Re: Tilton clutch kit! (94gsr4dr)
God Damn! 6 pounds!?!?!?!? WTF...lol thats tooo light
Old May 23, 2004 | 10:26 AM
Rod.'s Avatar
Default Re: Tilton clutch kit! (99SiRacer)
6 lbs damn
Old May 23, 2004 | 10:33 AM
Suprdave's Avatar
Default Re: Tilton clutch kit! (redturbocivic)
its not bad
Old May 23, 2004 | 10:51 AM
G
sh!t happens.
Default Re: Tilton clutch kit! (Suprdave)
that is a light fly wheel.... how much would it effect the performance?
Old May 23, 2004 | 10:58 AM
J337_UNIT's Avatar
Default Re: Tilton clutch kit! (G"UNIT)
i like light flywheels
Old May 23, 2004 | 11:15 AM
done's Avatar
Default Re: Tilton clutch kit! (J337_UNIT)
to light for boost, im gonna have to shift fast as a motha
the assembly weights 14.8 lbs, thats lighter then my stock flywheeler
Old May 23, 2004 | 11:20 AM
TrueNorthStar's Avatar
austrian type-R is running the carbon setup in his car. Sounds to me like he likes it alot.
Here is his post: <U>https://honda-tech.com/zerothread?id=867027</U>
Old May 23, 2004 | 12:15 PM
B18C1CYA's Avatar
how much does all of the clutch weight together? maybe it will even out the wieght i dont know just a thought
Old May 23, 2004 | 12:26 PM
94gsr4dr's Avatar
Default Re: Tilton clutch kit! (B18C1CYA)
EVERYTHING weighs in at 14.8 pounds
Old May 23, 2004 | 12:32 PM
B18C1CYA's Avatar
wow thats still pritty light , that thing will rev to the moon i hope my 8lb fidanza will not be to light
Old May 23, 2004 | 04:22 PM
Pengo's Avatar
damn, is that 6lb's aluminum or chromoly? up that rev limit and pretend ur a bike
Old May 23, 2004 | 04:27 PM
Rob Dizzle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">to light for boost, im gonna have to shift fast as a motha
the assembly weights 14.8 lbs, thats lighter then my stock flywheeler</TD></TR></TABLE>
why?
having 200whp more than stock will make your engine rev faster.
you just have to watch your tach and know when to shift
Old May 23, 2004 | 04:29 PM
m R g S r's Avatar
Default Re: Tilton clutch kit! (Bob-DC2)
Jordo, I think you should be alright. The few people that could afford that clutch on here have said that it's not too bad as a daily driver, actually that it was very streetable.
Old May 23, 2004 | 04:30 PM
alpha's Avatar
Default Re: Tilton clutch kit! (m R g S r)
I guess he will put Hondata's rev limiter to the test I know I did in my buddy's ITR and he had a stock flywheel but quite a bit more power.
Old May 23, 2004 | 07:03 PM
DIRep972's Avatar
Smarter than you
you really can't judge a flywheel combo until you drive the car... Some combinations its gonna work nice w/, some it won't, some drivers love it, some can't control it..
Jordo, are you running an harmonic dampener on ur built engine? (like a fluidamper?)
Old May 23, 2004 | 07:10 PM
alpha's Avatar
Default Re: Tilton clutch kit! (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">you really can't judge a flywheel combo until you drive the car... Some combinations its gonna work nice w/, some it won't, some drivers love it, some can't control it..
Jordo, are you running an harmonic dampener on ur built engine? (like a fluidamper?)</TD></TR></TABLE>
That's exactly what I told Jordo. I told him if he likes it keep it and if he doesn't like it sell it. Don't keep something you don't like. Also, to my knowledge he doesn't need an aftermarket harmonic dampener on a stock bottom end You probably thought this was his other built motor. I wish I had two B18c5 too
Old May 23, 2004 | 07:22 PM
B18C4-T's Avatar
Default Re: Tilton clutch kit! (0x64)
I just got my tilton twin disc, why are you asking about having a fluidamper? I'm just curious because mine is fully built and I can't afford to do it again. Thanks, Larry
Old Jun 28, 2004 | 05:19 PM
Flamenco-T's Avatar
Default Re: Tilton clutch kit! (B18C4-T)
Anytime you changed the geometry or the balance of the motor from one end to another end of the crank, you're risking is running your motor unbalanced. The stock dampener only able to counterweight close to similar setup, when you run tilton disc, you're changin the weight of one end about 12-13 lbs.
The fluidamper being liquid filled on the inertia helps counterbalance and reduce fritcion and wear on your bearings and oil pump.
I always try to offer the fluidamper with customer who bought or interested in the Tilton. For $ 350 they're a good insurance to have.
Stan
Old Jun 28, 2004 | 05:21 PM
IMSTOCK's Avatar
Shoulda went exedy twin disc.
Old Jun 28, 2004 | 05:31 PM
quik sol's Avatar
I got the act streetlite and its good enough for me.
Old Jun 28, 2004 | 07:15 PM
Dublocivic's Avatar
Default Re: (IMSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">Shoulda went exedy twin disc.</TD></TR></TABLE>
Yeap Im going Exedy twin disc.. to me there are to many reasons not to.
Old Jun 28, 2004 | 07:37 PM
djdxm's Avatar
Default Re: (Dublocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dublocivic &raquo;</TD></TR><TR><TD CLASS="quote">
Yeap Im going Exedy twin disc.. to me there are to many reasons not to.</TD></TR></TABLE>
what are your reasons? Just curious. Exedy makes great products and so does Tilton.
RGK500
Oct 2, 2006 07:31 PM
quik2kSi
Dec 19, 2003 08:47 AM
Heisdan
Jun 25, 2003 07:20 AM
