is this a tig welder????
Old Apr 27, 2004 | 03:40 PM
Ivan's Avatar
senior gold member
Default is this a tig welder????
for 14 years my dad has had this welder and I just noticed it said tig. I was gonna buy a tig welder sometime this summer but if I can practice on this, it would be better. Here's some pics.
Old Apr 27, 2004 | 03:49 PM
david@didrace.com's Avatar
Default Re: is this a tig welder???? (Ivan)
Yes. Just make sure it's hooked up with a tig torch instead of a mig gun.
Old Apr 27, 2004 | 03:58 PM
Ivan's Avatar
senior gold member
Default Re: is this a tig welder???? (10-94-55)
its setup for mig right now. Its an old welder and hopefully I can the tig stuff for it. Aleast its a snap on
Old Apr 27, 2004 | 06:40 PM
Ivan's Avatar
senior gold member
wheres the welders at?
Old Apr 27, 2004 | 06:48 PM
5STAR3's Avatar
you should start on mig first if you havent already.
Old Apr 27, 2004 | 06:56 PM
Ivan's Avatar
senior gold member
Default Re: is this a tig welder???? (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">you should start on mig first if you havent already. </TD></TR></TABLE>
I have. I use this snap on and another one I have at home. I wanna learn how to tig.
Old Apr 28, 2004 | 06:36 AM
Ivan's Avatar
senior gold member
morning bump.
Old Apr 28, 2004 | 07:43 AM
racerxadam's Avatar
the problem with using that setup as a tig welder is that you have no amperage control. You have to set the amperage with the dial on the welder and work with it, most tig welders that you can buy will either have foot pedal or hand control to vary welding current for better puddle control. If you can get it set up for tig without spending too much, it might be worth looking into so that you can start to practice the movements needed for tiging. Once you get past the basics you will want a welder that has amperage control. Also it will only do lift arc DC tig.
Old Apr 28, 2004 | 09:01 AM
SiRex91's Avatar
Default Re: is this a tig welder???? (racerxadam)
Get a new tig welder. Tig welding technology has changed a lot since that welder was built (i.e. squarewave technology). Go for a new one and keep it forever
E-Rok
Welding / Fabrication
12
Jan 31, 2010 07:50 PM
mportedcivicsi
May 13, 2009 12:41 PM
revautousa
Jul 14, 2006 08:00 AM
EEK
Apr 23, 2004 09:24 AM
sloppy_seconds
Jul 2, 2003 07:30 AM
