Tial Wastegate & Boost Controller Question
Old Jul 18, 2004 | 07:09 PM
ek9vboi2's Avatar
Default Tial Wastegate & Boost Controller Question
I've done some research and came up with **** diddly squat! lol...anyways...its pretty simple...
As most of you guys know, Tial Wastegates come with a certain amount of Pressure spring it in, I was wondering why is my boost controller not holding boost where i want it too.
38mm Tial Wastegate (9lb spring...I guess. Never Opened it up to see the color.)
Turbonetics Boost Controller (Manual)
I want it to be set at 2lbs or less, why won't it be my bitch and do as i say?
Yes I hooked it up right... Manifold/Turbo Pressure to the Inlet of the Boost controller and then out to the Wastegate (Side port). Top is open.
LMK Guys
Old Jul 18, 2004 | 07:12 PM
B18C1CYA's Avatar
Default Re: Tial Wastegate & Boost Controller Question (ek9vboi2)
so you want to run less then 9 psi which is your spring size? if so you can not do that you can only run more boost then your spring not less.
Old Jul 18, 2004 | 07:16 PM
ek9vboi2's Avatar
Even with a boost controller? Damn!!! Ok thanks mang :thumbups:
Old Jul 18, 2004 | 07:19 PM
B18C1CYA's Avatar
Default Re: (ek9vboi2)
the boost controler will only let you raise boost over the spring rateing, but will not let you lower it below the springs rated psi. just thought i would clear it up a little better just buy a lower spring like a .4 bar if you want to run real low boost, then just adjust higherwith your controler.
Old Jul 18, 2004 | 07:22 PM
ek9vboi2's Avatar
Yea, but doesnt a new spring cost like 20-30 bucks? I think i should just deal with it till Mase comes to town and tunes my car.
Old Jul 18, 2004 | 07:23 PM
B18C1CYA's Avatar
you dont want to boost until your tuned just stay out of boost you should be fine and save the 30 bucks
Old Jul 18, 2004 | 07:55 PM
ek9vboi2's Avatar
Default Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote"> you dont want to boost until your tuned just stay out of boost you should be fine and save the 30 bucks </TD></TR></TABLE>
cant resist it....i love boost!!!! the greddy type s really gets me into it. lol...it blows off in Idle...is that normal? like real blow off, not that ***** ****, i've been turbo'd b4 too.
Old Jul 18, 2004 | 07:57 PM
B18C1CYA's Avatar
yup i here you boost to me is like crack to a crack head,
Old Jul 18, 2004 | 08:14 PM
ek9vboi2's Avatar
I can tell by ur sig. 11s...wow...just wanna hit 13s on a stock b20.
90Rexx
Jul 26, 2010 10:16 PM
Racer X
Mar 27, 2003 01:07 PM
vtec.dc2
Dec 28, 2002 08:03 AM
The Punisher
Jun 21, 2002 09:57 AM
DIRep972
Aug 18, 2001 03:34 AM
