Tial question
Old Apr 26, 2003 | 02:35 PM
RyanAutry's Avatar
Default Tial question
What is the ring for, that comes with the kit?
Old Apr 26, 2003 | 02:40 PM
b18bturbo's Avatar
Default Re: Tial question (RyanAutry)
that ring is the valve seat it seatsthe wg to the flange.
Old Apr 26, 2003 | 02:43 PM
RyanAutry's Avatar
Default Re: Tial question (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">that ring is the valve seat it seatsthe wg to the flange.</TD></TR></TABLE>
Opps, I didn't install that when I mounted the wastegate to the manifold...
I'll do that tonight.
But it doesn't fit in there flush. I have to apply pressure to the sping in-order to get it to mound flush on the flange.
Old Apr 26, 2003 | 02:44 PM
b18bturbo's Avatar
you have to install that for air tight seal or you wont be boosting nayhting...
Old Apr 26, 2003 | 02:46 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">you have to install that for air tight seal or you wont be boosting nayhting...</TD></TR></TABLE>
Good to know. Thanks.
Many more questions to come. Started the Install last night after 7 months of waiting.
b18bturbo's Avatar
awesome.. good luck on the install if you have questions post them here many people are here to helpp...
Old Apr 26, 2003 | 02:49 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">awesome.. good luck on the install if you have questions post them here many people are here to helpp...</TD></TR></TABLE>
I sure will. Because H-T Rocks.
Thanks for the help btw.
Old Apr 26, 2003 | 03:08 PM
Precision DC4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for the help btw. </TD></TR></TABLE>
hahaha man where do you get those little smiley guys, they're hilarious
Old Apr 26, 2003 | 04:33 PM
Quick 200k Mile Motor's Avatar
I remember that ring. It aligns the connection dead center and clings to the flange so you wont have any leaks.
I wish I can use a ring like that on all my exhaust connections.
Old Apr 26, 2003 | 04:45 PM
RyanAutry's Avatar
So, does the little lip go inside the Tial? or does the little lip mount into the manifold?
Old Apr 26, 2003 | 04:49 PM
b18bturbo's Avatar
lip goes inside you should have a true flat service on the wg moutning side
Old Apr 26, 2003 | 05:03 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">lip goes inside you should have a true flat service on the wg moutning side</TD></TR></TABLE>
I get it.
Old Apr 26, 2003 | 05:05 PM
skhonda's Avatar
just make sure when you install it, that it's flush and there is no gap between wastegate and manifold... i made that mistake and the w/g was venting at idle, lol.
Old Apr 26, 2003 | 05:19 PM
RyanAutry's Avatar
Default Re: Tial question (skhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skhonda &raquo;</TD></TR><TR><TD CLASS="quote">just make sure when you install it, that it's flush and there is no gap between wastegate and manifold... i made that mistake and the w/g was venting at idle, lol.</TD></TR></TABLE>
I add the gasket right? That should seal any leaks, right?
Old Apr 26, 2003 | 05:22 PM
b18bturbo's Avatar
you talking about the paper gasket it will probably blow it couple days.. its peice of **** gasket.. but really dont need it if you surface is true and clean.
Old Apr 26, 2003 | 05:27 PM
RyanAutry's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">you talking about the paper gasket it will probably blow it couple days.. its peice of **** gasket.. but really dont need it if you surface is true and clean.</TD></TR></TABLE>
lol
ok, no gasket then.
I wonder how many pages this thread will be before I get this installed right. lol
&lt;-- Me
Old Apr 26, 2003 | 08:42 PM
turbosi03's Avatar
I was wondering about the gasket myself. I might buy the Tial wastegate used and the guy said he didn't use the gasket, silicon instead. should I buy that or does it sound fishy?
Old Apr 27, 2003 | 07:41 AM
Foozball26's Avatar
Default Re: Tial question (turbosi03)
just pickup a turbonetics gasket, they have a metal ring on the inner part and that will solve the wastegate gasket blowing problems.
Old Apr 27, 2003 | 09:16 AM
ryu12341's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote">What is the ring for, that comes with the kit?
i have a question. i have a blitz dual solenoid boost controller and im not sure which vacuum line to hook up to the wastegate. when i had the deltagate on my motor, it hooked up to the side of the wastegate, not the top. But with the tial, there is the one on the side and one on top. im not sure which vacuum line i should hook up to: the top one, or the one on the side. can anyone help me out?
GenIIIMrDuece
Welding / Fabrication
Nov 30, 2007 06:08 AM
J.nguyen
Jun 1, 2006 06:25 AM
civicb18c
Feb 2, 2005 09:28 PM
scartail
Oct 9, 2004 04:24 AM
baddassduramax
Nov 26, 2003 09:42 AM
