Tial maximum boost setting?
I read this about the Tial External Wastegate 35mm on importparts.com:
"...Boost adjustable up to 18psi with boost controller."
Does this mean that I can boost up to 18 pounds and no more?
Oh by the way I have a B18C1 with a Drag III turbo kit, Inline Pro lower compression head gasket, 440cc injectors, AFC, 255lph fuel pump, and I run the tial wastegate. Just waiting to get a clutch before I take it to the track.
your stock motor wont take anymore any way u look at it... and at 18 lbs with fuel management it may not last long... and i know someone running 20+ psi on the 35mm with no problem
