Thread on header bolts? need to put stage 8 on.
Old Nov 1, 2013 | 09:23 AM
MalcolmV8's Avatar
Default Thread on header bolts? need to put stage 8 on.
Hey guys,
Over time I've fixed all my turbo related bolts & nuts vibrating loose with the exception of the manifold to the cylinder heat nuts. The last issue that still plagues me with coming loose. So I want to install some Stage 8 locking fasteners. Anyone know what the correct one to order is? They have various sizes and thread pitches. I have a D16Y8 stock head with stock studs sticking out.
http://www.stage8.com/imports.html
Thanks
Malcolm
Old Nov 1, 2013 | 10:14 AM
F22Master's Avatar
Default Re: Thread on header bolts? need to put stage 8 on.
M8x1.25mm
Old Nov 1, 2013 | 10:25 AM
F22Master's Avatar
Or just get some regular M8x1.25 bolts and drill the heads and safety wire them.
Old Nov 1, 2013 | 10:50 AM
turbohatch96y7's Avatar
X2 on safety wire.
Old Nov 1, 2013 | 10:58 AM
MalcolmV8's Avatar
Thanks for the sizing. I'll just get the Stage 8s. I've used them in the past on other vehicles and I really like them a lot. Very easy to use and work well.
Old Nov 1, 2013 | 11:36 AM
Charlie Moua's Avatar
how do they work?
Old Nov 1, 2013 | 12:23 PM
MalcolmV8's Avatar
Originally Posted by Charlie Moua
how do they work?
If you look at the link above the pictures almost self explain it. So the bolts or nuts (which ever style you need) have a hex head like normal bolts except there's a grove cut all the way around where a C clip can go on. After you've fastened the nut down you have a bag of guitar looking pics best I can explain them. They have a hole cut in them with a ton of teeth in an off set manner. You slip it over the head of the bolt so that the ear piece sticking out is touching or almost touching the exhaust manifold tube in the backing out direction of rotation. Then place the C clip on to snap and hold in place. Now the bolt can't ever back out unless you remove the C clip and pull that ear piece off.
It goes really quick. You just install all their nuts or bolts and once done put those tabs on and snap on the C clips and done.
sr20paisa
Aug 31, 2015 11:31 AM
slvrcvc93
Jul 21, 2008 02:56 PM
miahmouse
Aug 17, 2006 07:27 AM
D.Dappa
Mar 11, 2005 07:53 PM
Agent STFU
Jul 24, 2003 11:09 PM
