Thoughts or recommendations
Old Aug 31, 2004 | 07:41 PM
  #26
Touge Tuning's Avatar
TTT
Old Aug 31, 2004 | 08:03 PM
  #27
Chris F's Avatar
Default Re: (scarlemthug)
Looks good.
440 cc vs. 550 cc won't really matter. I have the 550 cc's now and it idles like stock with Hondata. So flip a coin.
Old Aug 31, 2004 | 08:07 PM
  #28
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarlemthug &raquo;</TD></TR><TR><TD CLASS="quote">Any advantages using 2.5" for all the piping?
not really but it won't kill your setup either. I like to use whatever size the compressor discharge is then a silicone reducer at the turbo. On my own car I have the hot pipe taper from 2" up to 2.5" over a distance of about 12". This is probably the smoothest design, which should will add the least amount of heat to the charge air.
Old Sep 1, 2004 | 10:30 AM
  #29
Default Re: (ccfries)
Someone mentioned that I should go with the 525cc injectors because it would be better to be on the safe side than try to get too much out of the 450's.
Old Sep 1, 2004 | 10:34 AM
  #30
So I wouldnt gain or lose any power going with all 2.5" piping? So your saying you have a 2" downpipe that flares to 2.5"?
I guess I will just do 2" to the IC and then 2.5" to the TB.
Thanks
Old Sep 2, 2004 | 10:55 AM
  #31
What cams and intake manifold would you recommend if I wanted to get more torque and power in the low and mid-range?
Old Sep 2, 2004 | 05:04 PM
  #32
UP
Boosteddc2gsr
Feb 2, 2005 09:20 PM
Elemental
Jan 27, 2005 10:28 PM
TrumpTiteJoker
May 15, 2004 11:11 AM
igo4bmx
Dec 18, 2003 11:48 AM
