thoughts on a Precision Turbo 5252e
Old Sep 9, 2011 | 02:37 PM
90cobraclone's Avatar
Default thoughts on a Precision Turbo 5252e
wanting to run it on a stroked b18 bought the goautoworks pro kit 3" dp with 750
cc injectors,skunk 2 pro manifold , dh racing p&p b16 head, with gsr cams just
having second thoughts i bought wrong turbo
Old Sep 9, 2011 | 03:11 PM
92redhatch's Avatar
Default Re: thoughts on a Precision Turbo 5252e
Tiny
Old Sep 9, 2011 | 03:20 PM
racebum's Avatar
what's your hp goal? that's a 60lb/hr turbo if i remember right. should be good for 450whp without trouble....probably more
that said, for what they cost i'm surprised you didn't get a 6262
Old Sep 9, 2011 | 03:33 PM
Casey's Avatar
Originally Posted by 92redhatch
Tiny
do you even know what it is? lol. even if something is called a 5252 its not a 52mm turbo.
its basically a 60-1 with a stage 5 exhaust wheel. its a great street turbo for your setup. i was going to run one on my 84x87 motor for 450 on pump but sold it to a friend that needed a turbo asap.
Old Sep 9, 2011 | 05:24 PM
92redhatch's Avatar
I think for his setup if he wants a street car and doesn't plan on making more then 550whp its fine. I said tiny because nowadays smaller turbos aren't as popular
Old Sep 9, 2011 | 06:08 PM
was shootin for 400+ so my 750cc injectors should be enough
Old Sep 9, 2011 | 07:10 PM
racebum's Avatar
you'll easily make 400+ with that turbo. can't remember where 750s max but depending on compression you might be octane limited. most the 400+ hp builds go to e85 for just that reason, and, with e85 those injectors are too small for 400+
Old Sep 9, 2011 | 09:18 PM
cr will be around 8.5. what size injectors would i need there no e85 around here
Old Sep 10, 2011 | 08:22 PM
TheShodan's Avatar
Moderator
At least 750cc is need for 400whp. You won't make it without some sort of fuel modifyer like Meth/water or race fuel with that low of a compression.
Old Sep 10, 2011 | 08:52 PM
racebum's Avatar
which brings up another point...why in the world would you want 8:5-1 on a street car? engine will be more responsive at 9:5-1 or 10:1
Old Sep 11, 2011 | 03:20 PM
Why will i suffer with 8.5-1 compression?
Old Sep 11, 2011 | 03:31 PM
TheShodan's Avatar
Moderator
takes more boost pressure to get the same power level as with a slightly higher compression. Off boost response DIPS BIG in between shifts with lower compression . What you have as a turbo is ok, as the "sweet spot" of efficiency is from 14-26psi,but it will take over 18psi just to get close to you to your 400whp goal.
Old Sep 11, 2011 | 03:51 PM
so would getting a thinner head gasket benefit some?
Old Sep 11, 2011 | 03:54 PM
00Red_SiR's Avatar
All Motor Mentor
for every layer you remove, you only bump compression .2
You'd need to shave the head or go with flat faced valves to make any real difference.
Old Sep 11, 2011 | 07:29 PM
Coheed's Avatar
low compression has its benefits. Cooler combustion temps allow you to run more boost without detonation, which is a benefit of a lower compression. High boost big AR setups can make really good numbers for pump gas. Sure, they aren't as responsive out of boost, but they can be built to overcome that.
Old Sep 11, 2011 | 08:40 PM
TheShodan's Avatar
Moderator
True, but not when the turbo being used takes that long to get into the best efficiency "island". 9.0:1 and above is fine. Don't treat the car like its 1985 with super low compression to compensate for lack of ability to fine tune ignition timing and fuel curves. Its the 21st century, and to a point where yes, you can have higher compression, cool cylinders and great off boost response, if you're willing to get the right equipment and people to do it.
Old Sep 21, 2011 | 04:21 PM
thoughts on this turbo might have a chance to upgrade borg warners S366
Old Sep 21, 2011 | 05:55 PM
TheShodan's Avatar
Moderator
2 COMPLETELY different turbos with 2 COMPLETELY different uses. Time to think about what you want to do with this car, and not just go for the quick deal.
1000kg88hb
Mar 12, 2007 01:01 PM
splickitysplat
Aug 18, 2006 06:02 PM
DUB20VT
Jan 30, 2006 10:47 PM
Mr.c
18
Jul 8, 2004 02:09 PM
Papa G
18
Apr 2, 2002 04:11 PM
