For those of you wth Z10 trac. bars, need a quick answer!!!
I just got around to instaling the Z10's last night on the Civic, pretty straight forward with a couple hiccups here or there, nothing major (had to hack my charge pipe right off the turbo to clear the Z10 support fame)..
Anyways, my question is, which way do I preload the LCA's?? The instructions tell you to turn the arms CW for give postivie caster, CCW for negative, but it doesn't specify which one i'm looking for? After installing them, I turned the arms till I found the "neutral" setting where I could feel zero resistance on the arm meaning the LCA was centerd, so what I need to know now is, do I pull the LCA to the front of the car to preload, or do I push the LCA towards the back of the car?? Any help would be apprieciated as always
New User
Re: For those of you wth Z10 trac. bars, need a quick answer!!! (dustin)
do you think there will be a problem with the charge pipe getting in the way on my LS? i rather not hack anything...
the pipes clear
Re: For those of you wth Z10 trac. bars, need a quick answer!!! (PureTeg420)
Well, mine fit on the Civic, but like I said, it was a TIGHT fit as you can see here:
[Modified by VTC_CiViC, 4:41 PM 6/1/2002]
I am using the maxrev manifold that positions the turbo differently, but I don't see how it is enough to matter...
New User
the pipes clear
pipes don't clear on a drag 3 ls. mine didnt fit w/o modification, and a little over a month ago i installed some for a friend of a friend and they didnt clear either. I don't understand why they fit on your GSR...that driverside u-bend piece should be indentical for both cars.
VTC_CiViC
06-01-2002 01:21 PM
