Those with cometic head gasket?
Old May 16, 2002 | 06:40 PM
Ltech's Avatar
Default Those with cometic head gasket?
How thick are y'all going with these gasket? This is my set up
Golden Eagle 84mm, JE pistons 9:1
How thick would I go? I goal is around 400 whp-450 whp. I know the stock head gasket is .032
jason phan
Old May 16, 2002 | 07:02 PM
kamira's Avatar
Default Re: Those with cometic head gasket? (Ltech)
ttt. im intrested too.
Old May 16, 2002 | 07:04 PM
2K_TEG's Avatar
http://www.c-speedracing.com/howto/c.../compcalc.html
AND I think the stock head gasket is .029. What size gaskey you choose is totally dependent on what compression you want to run. Cometic makes: 0.036, 0.043, 0.057 (price jump), 0.098 and 0.112. Play with that calc until you get the compression ratio you want.
Old May 16, 2002 | 07:05 PM
earl's Avatar
Need much more info. Which block, which head, anything milled etc., stock stroke?
Old May 16, 2002 | 07:06 PM
2K_TEG's Avatar
Default Re: Those with cometic head gasket? (2K_TEG)
the piston dome displacement should be on the spec sheet you got from JE. with those pistons and the smallest cometic gasket, your comp. ratio will be in the high 8s.
Old May 16, 2002 | 07:09 PM
Ltech's Avatar
B16 block bore out to 84mm
b16 head open combustion chamber to match 84mm bore
over size valves 0.5mm
Yes stock stroke
[Modified by Ltech, 4:10 AM 5/17/2002]
[Modified by Ltech, 4:13 AM 5/17/2002]
Old May 16, 2002 | 07:38 PM
2K_TEG's Avatar
Yes stock stroke
What comp do you want to end up with?
Old May 16, 2002 | 07:47 PM
earl's Avatar
Stock thickness to .040 will be great. Cometics work.
Old May 16, 2002 | 07:54 PM
Ltech's Avatar
Default Re: Those with cometic head gasket? (earl)
8.8 because I will be running 20 psi +
Old May 16, 2002 | 08:15 PM
2K_TEG's Avatar
the .036 will put you right under 9.0:1, and the .043 will put you right under that. The fact that you are changing the cumbustion chamer lowers your comp a little right off the bat. If you find out your piston dome displacement you can find out exactly what you will be running. If I were you I would go with the 0.036.
Old May 17, 2002 | 04:05 AM
Ltech's Avatar
Sound good to me. Thank you
jason phan
EJ8_Man
Jun 25, 2010 10:16 AM
Honda4life777
Oct 9, 2009 08:36 PM
t57b18
Sep 19, 2006 04:54 PM
ochsy03
Apr 20, 2005 06:40 PM
