Thinking of going TURBO but what first?
Old Feb 17, 2004 | 07:53 PM
np0r's Avatar
Default Thinking of going TURBO but what first?
I was recently thinking of going turbo (not sure of which one yet) and im curious what i should do to my engine before i turbocharge it? Im currently using a B18C (JDM Type-R not GSR, some will think it is GSR ) with only I/H/E. Please list any mods that should be done in order before turbo installation.
Thnaks!
Old Feb 17, 2004 | 07:55 PM
J337_UNIT's Avatar
Default Re: Thinking of going TURBO but what first? (JDM2NR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM2NR &raquo;</TD></TR><TR><TD CLASS="quote">I was recently thinking of going turbo (not sure of which one yet) and im curious what i should do to my engine before i turbocharge it? Im currently using a B18C (JDM Type-R not GSR, some will think it is GSR ) with only I/H/E. Please list any mods that should be done in order before turbo installation.
Thnaks! </TD></TR></TABLE>
mods, only one i can say u should do for now is a strong *** clutch ... do a compression test..
Old Feb 17, 2004 | 07:57 PM
Silverbeast's Avatar
https://honda-tech.com/zerosearch
Start there and after some reseach you should get an idea of a good setup.
Then ask away
DaX's Avatar
DaX
Loved
Community Favorite
First, sit on the idea for a little bit. If you're just now thinking of going turbo, spend the next few months reading as much as you can and learning about what, why, and how turbos work. Next, set goals...how much HP do you want to run, how much money can you spend [often the two biggest questions]. Then lay out everything you'll need and make up a budget and start stocking up parts. I made the decision to go turbo about 2 years ago, and for the past 6 months I have actually been buying parts, and within the next two months, I will be driving my turbocharged civic.
Old Feb 17, 2004 | 08:01 PM
J337_UNIT's Avatar
Default Re: Thinking of going TURBO but what first? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">First, sit on the idea for a little bit. If you're just now thinking of going turbo, spend the next few months reading as much as you can and learning about what, why, and how turbos work. Next, set goals...how much HP do you want to run, how much money can you spend [often the two biggest questions]. Then lay out everything you'll need and make up a budget and start stocking up parts. I made the decision to go turbo about 2 years ago, and for the past 6 months I have actually been buying parts, and within the next two months, I will be driving my turbocharged civic.</TD></TR></TABLE>
i would have to say this is the best answer
it took me a while before i was fully ready to decide to go with it...then spent countless hours here learning, reading, searching for every bit of info i could get my brain in on and now ive learned so much about how my set will run etc...
Old Feb 17, 2004 | 08:03 PM
np0r's Avatar
Appreciate the help and everything but im curious on what mods would the engine need in order for it too handle the turbo w/o f'ing up my engine? Like UNIT said i needed a strong *** clutch, but i mean anything internally to the enginge or u think the B18C should do fine as it is now?
Old Feb 17, 2004 | 08:06 PM
DaX's Avatar
DaX
Loved
Community Favorite
With proper engine management, the b18c should be capable of 10 or more psi on a stock bottom end. you will need larger injectors, and definately a good EMS.
Old Feb 17, 2004 | 09:33 PM
rhettster's Avatar
This link single-handedly makes Honda-tech the coolest site on the net:
https://honda-tech.com/zerothread?id=268110
Old Feb 18, 2004 | 04:57 AM
maxxd97's Avatar
Default Re: Thinking of going TURBO but what first? (rhettster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhettster &raquo;</TD></TR><TR><TD CLASS="quote">This link single-handedly makes Honda-tech the coolest site on the net:
https://honda-tech.com/zerothread?id=268110</TD></TR></TABLE>
Agreed! That thread is awesome!
cartel420
Jun 24, 2006 07:36 PM
acintegragsr
Oct 14, 2004 12:29 AM
redvic
10
Jan 22, 2004 12:32 PM
..::91TEG-G2::..
Aug 16, 2003 03:36 PM
nighthawk teg 01
Oct 7, 2002 04:37 PM
