Thinking about going FI.
I have a B16 with a ITR head. I was just wondering how much boost would i be able to pull off without having to build the motor up. plan on running 6-10 lb of boost. This car will be a daily driver. Also what injectors would you recommend. I heard you can use a CX manifold for a turbo manifold is this correct?
psi is relative. power is not. 6 psi off a large t4 would probably put out more power than a t25 at 10 psi.
a cx manifold will not fit a b-series motor. that is a d-seires hack.
do some reading around here.... there's tons of good info.
