Thinking about boost.
Old Apr 21, 2004 | 11:59 AM
95GSRTT
Guest
Posts: n/a
Default Thinking about boost.
I have a 95 GSR with almost 140,000 miles on the engine. So I figure I should probably rebuild the engine before I decide to boost. Since I will be on a pretty tight budget for the rebuild. Would using LS pistons lower the compression of my GSR? And if so, wouldnt that be the best way to go for boost?
Old Apr 21, 2004 | 12:01 PM
DaX's Avatar
DaX
Loved
Community Favorite
Think harder...think until you're sick of thinking, then think some more.
LS pistons will drop your compression.
Don't boost until you think about it a lot.
Old Apr 21, 2004 | 12:07 PM
BEV@GSCMotorsports's Avatar
Default Re: (DaX)
yeah, that would probably be your best way to go if your on a tight budget, but your gonna have to keep the boost down a little.
Old Apr 21, 2004 | 12:12 PM
95GSRTT
Guest
Posts: n/a
Default Re: (CivicTurbo12)
Would that be, because the LS pistons are not as strong? I thought that lowering the compression, would make it easier to use more boost. I know its fine to boost on the stock bottom end of a GSR around 7-10 psi, Thats all I would do with the LS also. I just figure It would be easier on the engine with a lower compression, and a loss of maybe 10 hp? Am I right in thinking this or way off base?
And trust me Im researching a **** load before I even touch the engine. As Im still stuck between N/A or FI.
Roofrack
Mar 22, 2009 10:44 PM
rsx13k
May 25, 2007 12:38 PM
YellowCivic95
Apr 27, 2002 07:59 AM
austrian type-R
Jul 6, 2001 01:07 PM
