Are these Vacuum Readings normal?
Old Jul 9, 2004 | 09:58 AM
Alchemist's Avatar
Default Are these Vacuum Readings normal?
Please tell me if these readings are normal. This is on a stock b18b, not boosting yet. At idle the gauge reads vac. 20. When I give it a quick rev to 4000 rpm and let off quickly the needle hits 0 and then dips down to vac.26-28 and then back to 20. Is this normal??? I thought that it should only read between vac.20 (idle) and 0 (full throttle)?
Also, when I rev the engine to about 5000 rpm and leave it there, the needle goes from vac. 20 to 0 and then quickly falls back down to vac. 22-24.
Ive already tried this on two gauges cuz, I thought that the gauge was broken, but maybe it has something to do with my car?
Old Jul 9, 2004 | 11:08 AM
Alchemist's Avatar
Default Re: Are these Vacuum Readings normal? (Alchemist)
bump
Old Jul 9, 2004 | 11:12 AM
PM-Performance's Avatar
yes its normal
Old Jul 9, 2004 | 11:17 AM
AspectIndustries's Avatar
Default Re: Are these Vacuum Readings normal? (itr206)
Weird, mines goes from Solid 18 to 0 to 18....
Old Jul 9, 2004 | 11:37 AM
minivan81's Avatar
This is totally normal.
Old Jul 9, 2004 | 12:37 PM
Alchemist's Avatar
Default Re: Are these Vacuum Readings normal? (minivan81)
Are you guys sure??? Why would there be more vacuum than at idle? With the throttle closed it would seem that this is the greatest point of vacuum (vac. 20). What is the reason for the vac. drop as the revs go down? I dont get it, but Im glad that you guys have had this same experience. I was getting worried.
Old Jul 9, 2004 | 01:59 PM
B18C1CYA's Avatar
my vac at idel is like 18-19 but then on the highway and i let off it gos to like 23-24, iguess it has somthing to do with your compression ratio also.
Old Jul 9, 2004 | 02:45 PM
IN VTEC's Avatar
When the throttle plate is closed, there's very little atmospheric air (and pressure) to fill the manifold, so the vacuum reading is high.
The amount of vacuum the engine can pull is dictated by its valve-piston timing events. The amount of vacuum your gauge and MAP sensor reads depends on that above and the amount of atmospheric air coming into the manifold (determined by throttle position).
The higher the rpm, the more air the engine can pump out of the manifold. This is still assuming that the throttle position doesn't change. With no extra air to take its place, the vacuum reading goes up.
Comparison:
When you're cruising and take your foot off the throttle (throttle plate closed completely), the vacuum will hit its highest point. Compare that reading to when you're at idle (throttle also closed) and you'll see that at higher rpm's, the engine creates a greater amount of vacuum in the manifold.
When you're blipping the throttle, you open the throttle to atmospheric air (gauge reads roughly 0) and then it immediately closes, but the engine is still revving down from whatever rpm it was at (gauge reads high vacuum) until it hits idle, where the vacuum will eventually settle to its regular idle vacuum.
I'm really bad at putting together coherent thoughts into words when I'm hungry, so I hope you can comprehend it easily.
Old Jul 9, 2004 | 04:57 PM
MiraiZ's Avatar
Default Re: Are these Vacuum Readings normal? (IN VTEC)
my needle jumps to 0.1BAR when I rev
but yeah...sounds pretty normal. Gauge should be reading vacuum in neutral, and jump to 0 (which is atmospheric) if you turbo doesn't spool in neutral.
kaivorth
Honda Civic (2001 - 2005)
Dec 20, 2017 11:53 AM
jdmstreethatch
Oct 25, 2006 01:26 PM
B16Civic93
Mar 19, 2005 07:00 PM
eg92b16a2
Nov 29, 2004 09:50 AM
clsmooth
Feb 15, 2004 11:18 AM
