Theory on DSM inj. wiring
Old Mar 4, 2003 | 08:37 PM
Hondatec38's Avatar
Default Theory on DSM inj. wiring
I see that in wiring the DSM injectors, most people are using a resistor pack or single 8 ohm resistors inline to the common power wire (yellow and black) on each injector. Some people confuse these wires for a common ground. The injectors are pulsed using switches, via ECU transistors, to ground. Those are the specific injector (colored) wires. I know on my 1999 Si that the same single common power wire (yellow and black) is right at my ECU harness. In theory, could I use just one single 8 ohm resistor inline to all of the injectors before the wire is split into four? Remember this is a theory...just need input as to why this may not be the correct route. Thank You.
Old Mar 4, 2003 | 08:41 PM
UberTeg's Avatar
Default Re: Theory on DSM inj. wiring (Hondatec38)
too risky, when the injector duty rate becomes high, you could starve the injectors for power, ,causing your car to run lean. I got 4 inline resistros for $2, dont try to s ave $1.50 at the expensive of your engine.
Old Mar 4, 2003 | 08:43 PM
Hondatec38's Avatar
Default Re: Theory on DSM inj. wiring (UberTeg)
Thank You. Didn't think of that. It's not a money issue really, just trying to see if I was on to something. Thanks again.
Old Mar 4, 2003 | 08:57 PM
MikeMAN's Avatar
think of it this way, u are cutting 8ohms and 10watts (i think its 10), before the initial split to 4. By the time it splits into 4, u have only cut ur resistance to 8/4 ohms for each injector and 10/4 watts for each injector
chrysanderson
14
Nov 7, 2010 09:08 PM
Jayman_Gsr
Nov 21, 2008 05:18 AM
schwett
Dec 30, 2003 01:38 PM
c1hatch
Apr 23, 2002 06:42 PM
karmannghia
Mar 20, 2002 09:58 AM
