Test pipe users....where do you put your O2 sensor?
Old Mar 26, 2002 | 12:01 PM
shamoo's Avatar
Will you make something up for me please?
Default Test pipe users....where do you put your O2 sensor?
I just put in my test pipe, but where should I stick my O2 sensor?
I know I'll run a code, but I just need to know where I can secure it to. The shift linkage?
Where do you guys secure it? Thanks.
EDIT: I have no more zip ties left
[Modified by shamoo, 4:02 PM 3/26/2002]
Old Mar 26, 2002 | 12:04 PM
riot's Avatar
Default Re: Test pipe users....where do you put your O2 sensor? (shamoo)
Hmmm...I take it you are OBD-II then...well, you can have a bung welded on and plug it up. Then get an O2 sim?
-ryan
Old Mar 26, 2002 | 12:22 PM
shamoo's Avatar
Default Re: Test pipe users....where do you put your O2 sensor? (riot)
Yeah, I wanted to avoid doing that...too much trouble and I have no money left after this damn rebuild. I've heard people just like zip tie it somewhere.
Old Mar 26, 2002 | 12:40 PM
D-SPEED's Avatar
ive heard of people just using a zip tie on the linkage. You can also just disconnect the sensor and leave the wire hanging...er wait that would probably be an automatic code right there
[Modified by D-SPEED, 1:40 PM 3/26/2002]
Old Mar 26, 2002 | 01:17 PM
Mr. Vapor's Avatar
Default Re: Test pipe users....where do you put your O2 sensor? (D-SPEED)
me and some other guys on here have "fooled" the ECU. wrap the sensor in Tin Foil, then put it in a zip lock bag (still connected to the harness) and just zip tie it to the shift linkage stabilzer bar (the one that doesnt move) the tinfoil fools your ECU into thinking it is working! if you disconnect you'll most likely go into safe mode. gotta keep it connected. im 6 months with no CEL yet running a test pipe!
Old Mar 26, 2002 | 01:30 PM
niedejb's Avatar
Default Re: Test pipe users....where do you put your O2 sensor? (NYb16)
I have instructions on my website if your interested. Or see here:
Old Mar 26, 2002 | 11:12 PM
shamoo's Avatar
Default Re: Test pipe users....where do you put your O2 sensor? (niedejb)
Sweet! Thanks dude. I'll try that in the morning.
RSant
Oct 25, 2006 01:09 PM
sickofitall1113
Jun 9, 2005 12:18 PM
Chris_Bye
May 1, 2005 07:56 AM
