Temp gauge problem since boost.
Old Jul 18, 2006 | 03:09 PM
teamlegacy's Avatar
Default Temp gauge problem since boost.
Hey all, I recently just boosted my 4th generation Accord and have a head-pounding issue with my temperature gauge. It was acting perfectly fine before I boosted the car and now it is malfunctioning.
While tuning, Uberdata AND Crome both registered cruising temperatures between 195-197 but my gauge would always read hot. As soon as I'd goose the gas a little, the gauge would drop the the halfway mark. Over the last week, I have replaced the thermostat, the radiator cap, the radiator (with an all aluminum unit), and both the temperature sensors underneath the distributor, I even re-wired one of the sensors because the clip was busted. Not only have I done those things, but it's been bled 3 times using 2 different methods.
I have a cooling fan running whenever the ignition is on, but the other fan does not come on at all it seems. I'm not sure.
Has anyone run into the same or similar problem? I'm thinking I'm going to wire the other fan to run constantly as well and replace the other 2 sensors. Aside from those things if it doesn't work I'm fresh out of options. I appreciate any comments in return, thanks!
Colin
Old Jul 18, 2006 | 05:02 PM
teamlegacy's Avatar
Default Re: Temp gauge problem since boost. (teamlegacy)
Anyone have any input?
Old Jul 19, 2006 | 02:10 AM
teamlegacy's Avatar
Bring this to page 1, I need help!
Old Jul 19, 2006 | 04:33 AM
teamlegacy's Avatar
I may have solved my issue. I am going to reground the engine in 2-3 spots and wire that fan to stay on constantly. After a little digging it seems that a few of my grounds are flexing a little much since I had to remove the front torque mount.
acc0rdf22
Apr 11, 2010 03:05 PM
Paulie10
Jun 13, 2009 03:17 PM
scheistermeister
Jan 11, 2007 08:41 PM
si 1
Dec 31, 2005 07:44 PM
fish2win
Jan 11, 2002 04:27 AM
