Techedge WB Users
Old Sep 30, 2002 | 08:00 AM
tegtyper's Avatar
Default Techedge WB Users
I'm setting the heater current, and I am not getting the current to drop low enough after heat-up to enable the drive pump.
If I disconnect the heater (after initial power-up) then the heater current drops to zero and the circuit enables.
Wondering, does the sensor need to be in the exhaust gases as well, to get the temp up??
Old Sep 30, 2002 | 09:07 AM
Hal's Avatar
Hal
Default Re: Techedge WB Users (tegtyper)
Disconnect the heater? Do you mean unplug the o/2 sensor?
If the red led comes on with the sensor unplugged from the "controller", but does not come on when the sensor IS plugged in...
The unit is not getting enough voltage.
It needs as least 13.2v for proper sensor heater operation.
Hal
Old Sep 30, 2002 | 09:48 AM
falcongsr's Avatar
What is this crap?
Default Re: Techedge WB Users (Hal)
no the o2 sensor will heat itself up in free air no problem.
and Hal is right you gotta watch your voltage, it won't work in my car unless i have alternator voltage. battery itself wont cut it. my bench supply put out 13.7 and it worked fine. my living room was very lean! (lots of o2)
Old Sep 30, 2002 | 10:27 AM
tegtyper's Avatar
Default Re: Techedge WB Users (falconGSR)
I meant I just disconnected the heater wires, so the heater current dropped off.
My Bench supply was at about 13.6. The LM317 Reg has al litle over a volt drop out, so yeah you need to be above 13 for it to run.
Old Sep 30, 2002 | 11:11 AM
tegtyper's Avatar
I found the prob, or at least a way around it.
They spec the heater at 9.7 ohms at 800'C (full op. temp), and mine only gets to 1.09 Amps w/ 8.97V across it. this works out to 8.2 ohms. So the current will never drop to the expected level.
I guess there is some discrepancy between heaters? Also, I've got 15 feet of 24AWG feeding it, but that cant be more than a half ohm total..
Anyways, I increased R38 to 1.65K Ohms to trigger the drive cct a little earlier. ...
JDM_SOHC
12
Mar 28, 2009 02:52 PM
Perfectionist
Oct 20, 2006 03:36 PM
Civicman86
Apr 30, 2006 02:20 PM
antonio_pr2003
Oct 14, 2005 09:59 PM
horror
Mar 25, 2003 09:46 AM
